Disconnecting & Disassembling 120lb Propane Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2015, 07:32 PM   #1
Rewards Points: 53
Hi-
We have a great big propane tank sitting in our back yard - it's designed to feed a pool heater that no longer functions and we'd rather just not have it. Is there any particular science to disconnecting this thing? I think the gauge says it's actually 65% full which makes it mildly valuable - although it's covered in rust which is mildly alarming.
Top of Tank
Where the line joins the pool heater
corsulian is offline   Reply With Quote
Old 05-04-2015, 08:15 PM   #2
Rewards Points: 6,394
Mildly tap on the side of the gauge with a plastic screwdriver handle. If the gauge needle mildly bounces with authority and comes back to its original position we can be fairly certain it is correct.
The valve knob turned clockwise closes the supply. The hex tubing nut that connects the tubing to the valve probably has grooves cut into it. This means the threads are left hand.
The other round object next to the valve is the pressure relief valve that pops off in case of excess pressure. They usually just pop once with a sound of about five 10 gauge shot guns. At 65 percent that won't usually be a concern under normal temperatures a human can tolerate.
My advise is to call around to suppliers to see if any are interested in purchasing it. To be used it will probably need to be re-certified. There is internet information on certification.
Your second picture is the pressure regulator to the heater but I suspect you knew that.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
corsulian (05-05-2015)
Old 05-05-2015, 09:41 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Typically these tanks are owned by the propane supplier. Call them and ask them to remove it. They should give credit for the propane.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 05-05-2015, 11:32 AM   #4
Rewards Points: 53
Interesting. We've been here three years, it has no label, and there's no information about it. But thank you - I'll be calling the local supplier anyhow to see if they're interested.
Tags
pool , propane
Propane tank to fireplace connection question keith_andrews HVAC 2 11-21-2014 09:28 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Propane Tank for BBQ Irregular WayPeter General DIY Discussions 4 03-03-2009 01:28 AM
Propane tank was empty boiler does not start schrubber HVAC 3 12-30-2008 04:36 PM
propane tank jmgasior Plumbing 1 08-02-2008 04:25 PM
