Disconnect Vent Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2016, 07:26 PM   #1
Lord of Slums
Rewards Points: 1,974
Disconnect vent line
Cast iron pipe with galvanized metal branches. So I replaced the drain line that was leaking. There is a vent line where the metal tee is mounted halfway into the floor. I will have to cut the floor to connect into the vent line. Very confined space to work in.
I ran the drain and everything is working fine without the vent. The vent ties into a main stack about 4 feet from the floor. If I was to just cap the vent below the floor it would fill with sewage if their was ever a blockage. Is this a horrible thing.
mj12 is offline   Reply With Quote
Washing Machine Drain, line need an air vent? Richard Higer Plumbing 6 02-09-2016 04:20 PM
plumbing vent boilermaker27 Plumbing 5 09-26-2013 07:37 PM
Sewage line and vent design new basement bath JayRay Plumbing 8 02-04-2012 04:17 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Water Coming Out of Vent Line?? dost559 Plumbing 3 06-11-2008 08:50 AM
