Disassembling Black Pipe Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree10Likes
  • 3 Post By TarheelTerp
  • 2 Post By joed
  • 1 Post By Gregsoldtruck79
  • 1 Post By joecaption
  • 2 Post By joed
  • 1 Post By Guap0_
Old 02-08-2018, 05:47 PM   #1
Rewards Points: 960
Disassembling black pipe gas line
I need to disassemble the gas line and turn the highlighted elbow 90 degrees toward the white ducting. My goal is to run new line toward the right.
Should I spray PB Blaster on it and leave it overnight?
How can I turn the highlighted elbow toward the right without leaving the connection loose?
I picked up some pipe joint compound. I’ve heard people like using the tape and the compound in conjunction with one another.
thanks!
jaketrades is online now   Reply With Quote
Old 02-08-2018, 05:53 PM   #2
Rewards Points: 6,608
Re: Disassembling black pipe gas line
Take the ell off, clean the threads of any pipe dope, apply 4 wraps of Teflon tape and re-assemble with the 90 ell in the direction needed.
Old 02-08-2018, 05:57 PM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,704
^^ turn the gas off first
jlhaslip, Nealtw and Guap0_ like this.
Old 02-08-2018, 06:02 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 32,034
Use real pipe wrenches not vise grips or pliers. Should not need any PBblaster.
jaketrades and Guap0_ like this.
The Following User Says Thank You to joed For This Useful Post:
jaketrades (02-08-2018)
Old 02-08-2018, 06:08 PM   #5
Rewards Points: 88
I always ran my gas pipes with the image in my mind of my home blowing up from a gas leak
So I always make my black pipes joints with yellow gas pipe tape on cleaned threads, then apply that nasty, green funky pipe dope on the tape...back a bit from the threads end so it cannot get in the pipe later. Then, tightened it with pipe wrenches. Then check my work with soapy water for leaks when the gas is back on. JMO though. .
jaketrades likes this.
Gregsoldtruck79 is offline   Reply With Quote
The Following User Says Thank You to Gregsoldtruck79 For This Useful Post:
Old 02-08-2018, 06:12 PM   #6
Rewards Points: 19,008
Use yellow gas approved for gas tape or far better Teflon pipe dope, never white teflon tape!
That old plastic vent hose has to go!
It would take all of 30 sec. for it to melt and cause a fire.
If this was my job all that sheetrock would go, wall would be be built out so that vent could be run with solid Galv. without having to stick out from the wall!
Old 02-08-2018, 06:28 PM   #7
Rewards Points: 960
Just spoke with the building manager.
There’s no shut off valve for my condo unit and turning off the buildings gas is a pain because everyone’s pilot light needs to get relight.
I now recall when I first moved here, a plumber replacing my old shutoff valves to 1/4” turn valves while the gas line was on. He was pretty calm the whole time and me an idiot for standing next to him.
I’ll be giving him a ring tomorrow.
Old 02-08-2018, 06:45 PM   #8
Super Moderator
joed's Avatar
Being in an apartment building you are most likely not allowed to do this work yourself.
The plumber/gas fitter you call will know what to do.
joecaption and jaketrades like this.
Old 02-08-2018, 07:02 PM   #9
Guapo
Rewards Points: 11,950
Not installing separate valve is a cheap way to go. I ran into that in a 3 floor coop. I had to do some plumbing & I couldn't find a separate cold water valve. I still think that one existed although the owner said that she never saw it.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
Old 02-08-2018, 07:37 PM   #10
No location in your profile so impossable to know what local codes are.
Most would call for a permit, inspections.
If you do not own this building stop!
There should have been a shut off right behind the dryer and a flex line to make the final connection to meet even basic codes.
Old 02-08-2018, 08:31 PM   #11
Rewards Points: 80
Teflon isn't allowed in all jurisdictions. In others it must be natural gas rated. I otherwise agree.
OP: That gas fitter sounds experienced. He's a good idea.
Cheers!
supers05 is offline   Reply With Quote
Old 02-08-2018, 09:43 PM   #12
Rewards Points: 960
Moving the gas is part of a larger project. The washer and gas dryer are being moved from this location into the closet to the right. They will be stacked in the closet and connected to a washing machine box. (Drain, hot and cold lines)
The santee in the first pic is going to get spun 180 degrees and the drain will get moved into the closet. The gas will also get moved into the closet.
The copper supply lines run thru the closet so I will intercept them in the closet and install hammer arrestors on that line.
The dryer vent flume is to the right of the closet. I will tap into that flume with proper ridgid metal dryer venting. This is going to be a little tricky bc I’m tight on depth space but I think I have just enough to make it work.
And yes all that sheet rock is getting ripped out along with that plastic vent hose. I wonder if that hose actually makes it to the dryer flume.
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
insulating black pipe for gas hot water furnace anwhite80 HVAC 0 12-15-2010 10:11 AM
natural gas pipe line dave444 Plumbing 7 08-01-2009 09:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
