Direct Potable Reuse - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2016, 04:55 PM   #1
Rewards Points: 2
I am researching to see if a Direct Potable Reuse system would work for a single home.
What this system does is takes waste, filters it, and returns it to the water supply without it ever going back into nature, weather it be the ocean, underground (septic system), etc.
From what i know it has only been used by cities and not by lone residences.
The system I am wanting to create would be grey water only, sewage wouldn't be a problem due to a waterless composting toilet.
There are in line filters meant to supply an entire house, using water from a lake or river. The consist of a large filter, reverse osmosis filter, and a ultra-violet filter to eliminate bacteria. As long as chemicals/cleaners such as bleach aren't introduced, I don't see any reason this wouldn't work.
Using this system should mean that I won't need a septic system, and that I can use rain water to replenish my water supply as needed instead of digging a well as long as I have a holding tank for the dry months.
What are your thoughts on this?
Anyone out there have any experience with large filtration systems?
Rrtayatsamsiyu is offline   Reply With Quote
Direct Vent Water Heater Question kc27 Plumbing 2 02-12-2014 01:39 PM
Jaz's experience with BUILD DIRECT JazMan Flooring 1 06-08-2013 08:24 PM
direct venting question bubbler HVAC 3 10-07-2011 05:16 PM
Simpson Dura-Vent or Amerivent Direct Vent System? Fire4Effect HVAC 0 10-15-2009 02:39 PM
When wire needs to be outdoor / direct burial rated jamiedolan Electrical 23 02-25-2009 11:46 AM
