Diassambling This Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By jmon
Old 01-14-2020, 12:18 PM   #1
Rewards Points: 222
diassambling this faucet
one of my HW sink faucets is leaking.
digging in to see what needs replacing I am stumped at Step 2 - getting access to the guts of the spindle.
the grey plastic piece seems to have flats on it which would suggest that I would use a wrench to unscrew and remove it to pull out the brass post and whatever is below it and has failed. (Cartridge? O-rings? Packing? Rubber washer?)
but it doesn't budge. or at least not without the entire fixture spinning on the sink deck.
does this look familiar to anyone?
many thanks
Peter
pjstock is offline   Reply With Quote
Old 01-14-2020, 12:25 PM   #2
retired framer
Rewards Points: 5,916
Re: diassambling this faucet
That appears to have a U shaped clip you could remove to remove the washer and escutcheon???
Do not use flat bottom gables with scissor trusses.
Old 01-14-2020, 01:11 PM   #3
Rewards Points: 222
Ahhah. Bingo. correct.
Though what next? That grey piece still doesnt budge.
Should i have to remove the nut underneath and remove the entire assembly from above?
Old 01-14-2020, 01:36 PM   #4
retired framer
It does look like that would be the next step, I don't know what you do if it won't move.
Old 01-14-2020, 03:49 PM   #5
Rewards Points: 2,682
Looking at the pic, to me it looks like a 6 sided valve nut. Try using big channel lock or big cresent wrench see if it will unscrew. Use some wd 40 or pb blaster to help with the sediment.
Nealtw likes this.
jmon is offline   Reply With Quote
