DFU Calculation For 3 Full Bathrooms - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2016, 09:52 PM   #1
Rewards Points: 310
DFU Calculation for 3 Full Bathrooms
Hi Guys,
I am trying to determine the DFU's for three full bathr
ooms for my house. Two of the bathrooms are the same with a toilet, sink, and bathtub. The third bathroom has a toilet, sink and a shower with Two shower heads. Any help would be greatly appreciated.
Thanks,
Pat
patrickpresti is offline   Reply With Quote
Old 01-18-2016, 09:58 PM   #2
griz's Avatar
Rewards Points: 572
http://www.engineeringtoolbox.com/dr...es-d_1077.html
griz is offline   Reply With Quote
Old 01-18-2016, 10:40 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 290
Griz referenced UPC code. Here is a IPC chart as well http://publicecodes.cyberregs.com/ic...2_7_sec009.htm
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-19-2016)
Old 01-19-2016, 08:25 AM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Originally Posted by patrickpresti View Post
Hi Guys,
Thanks,
Pat
what do you need to know for? problems with system?
WhatRnsdownhill is offline   Reply With Quote
Old 01-19-2016, 09:16 AM   #5
Rewards Points: 310
I am trying to figure out the DFU's for the rough in plumbing for the main vent stack of my second floor addition but I am having a difficult time understanding figuring out the DFU's when grouping up the bedrooms.
Pat
Old 01-19-2016, 09:38 AM   #6
a licensed plumber will know what to do....as home owners are not aloud to do plumbing in most municipalities...
Old 01-19-2016, 09:54 AM   #7
Rewards Points: 310
I know a plumber can figure it out but I can figure it out as well with a little insight. I thought that's what the purpose of these forums are all about.
I am going to dry fit all of the plumbing, the plumber will glue it all together as we already agreed upon.
Old 01-19-2016, 12:41 PM   #8
knowing dfu wont tell you what fittings and how to configure the plumbing system, so if you have a plumber that will work with you, have him come over and explain and make notes for you on what todo...then you can do it and he can do the glueing and what not...and if you have a plumber already..ask him...hes going tobe responsible for what you do...
Old 01-19-2016, 01:10 PM   #9
Rewards Points: 310
Thank you
The Following User Says Thank You to patrickpresti For This Useful Post:
WhatRnsdownhill (01-19-2016)
Old 01-19-2016, 01:18 PM   #10
Plumber
Rewards Points: 290
Each of your bathrooms should vent with a min 2"
A 3" will vent all three bathrooms when combined.
However, my code requires the cross sectional area of the vents exiting the roof equal the area of the building drain- usually 4". So a little math is needed to insure the vents area equals the building drain area.
Old 01-19-2016, 01:54 PM   #11
Rewards Points: 310
EPlumber. Thanks for the info. I am in NY which follows ICC code. The drain pipe existing the basement of the house is 4"
On the second floor, my house has 2 full baths and a clothes washer. The first floor has a full bath and a kitchen sink on the first floor.
The house has an individual roof for each first and send floor where the fixtures are located. I am thinking it will be easier to run a main vent for the second floor fixtures out the roof and a main vent for the first floor fixtures out the roof.
I just want to make sure I have the main vent size for each floor going out the roof to be correct. Would 3" for each floor be adequate?
Thanks,
Pat
Old 01-19-2016, 04:16 PM   #12
Plumber
Rewards Points: 290
I can't say for sure Pat. It would work under UPC.
I suggest you hang on for a bit. Ghostmaker is an inspector that knows IPC real well. He might be on in a bit- he drops in quite frequently
Old 01-19-2016, 04:21 PM   #13
Rewards Points: 310
Ghost is great guy. He has helped me out big time. Thanks for the heads up.
Old 01-19-2016, 05:48 PM   #14
Rewards Points: 1,952
15 DFU total for 3 baths. IPC code. Each bathroom group in residential is 5 DFU.
Old 01-19-2016, 08:15 PM   #15
Rewards Points: 310
Thanks Ghost. I need to pick your brain about vent stacking when you have a moment...
3 bathrooms on one circuit Troy32 Electrical 48 01-03-2016 02:56 PM
New Faucet not running with full pressure teamcurtis Plumbing 3 07-13-2011 03:17 PM
Browse New Generation Bathrooms Design & styles bathroomsuk Plumbing 0 09-20-2010 01:38 PM
Crinkles on full wall drywall seams. Big issue? bteudt Drywall & Plaster 9 06-30-2010 04:16 PM
supply runs required in all bathrooms? bjherron HVAC 2 11-23-2007 07:56 AM
