? On Demand Electric Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree7Likes
Old 02-17-2018, 10:28 AM   #16
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,287
Re: ? On Demand Electric Hot Water Heater
I wish I knew more about the Pex, that blame thing is leaking again. In the picture the fitting that is connected to the 3/4 pipe is just barely leaking. I have changed out this fitting two times and I have retightened it three times. If I tighten it any more it will bust the fitting. I know I have plenty of the Teflon tape on it, is there another fitting I can use insted of that one? Ace Hardware is really proud of the fitting, with tax it is $7.64 each.
Another problem I have right now, I could not stop the water from contaminating my joint when I sweat it, so I use loaf bread to stop the water like I have in the past, now the blame stuff is clogging the strainers in out faucets. I hope when I change that fitting again I don't have to use loaf bread again.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-17-2018, 12:23 PM   #17
Rewards Points: 46
Must have bad machining on pipe threads. You say the tank nipple is new or the copper female adapter ? Both ? much easier t sweat on male adapter on copper along with an isolation valve. If you don't have torch set up to do this a compression adapter can be another option. Hopefully you can locate a fixture that is lower than pipe you are having the water bleed problem. Opening anything on the water system lower than the area you are working on should allow water to drain off there instead. Tools like a "jet sweat" can be great sometimes allowing you to install a(full port) ball valve and isolate off the water bleed off issue. Hope this helps. NOTE: threaded fittings in good condition with Teflon tape and pipe dope should seal without stress. Cranking down on it shouldn't be necessary. Usually makes things worse. (good call)
I will look for what you ended up doing.
Daron
Daron Dyer is offline   Reply With Quote
Old 02-17-2018, 12:30 PM   #18
Ole Wood Worker
BigJim's Avatar
Daron
Daron, I will let you know what I do to fix this, but right now I got a motor to put in our grandson's car. I appreciate your information.
Jim
Old 02-17-2018, 12:35 PM   #19
Naildriver
chandler48's Avatar
Rewards Points: 3,596
Of course hindsight is perfect, but using static pipe to make that final connection could be your nemesis. Using a corrugated water heater connector and a 3/4" Male adapter back aways would have allowed you to eliminate any small leak and not have to use any thread sealant. Are those dielectric nipples or common galvanized ones?
https://www.homedepot.com/p/BrassCra...-18N/203871937
https://www.homedepot.com/p/Everbilt...5009/205680991
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 02-17-2018, 12:36 PM   #20
Rewards Points: 46
Ok, Have a good day Jim. Good Luck !
Old 02-17-2018, 06:36 PM   #21
Ole Wood Worker
BigJim's Avatar
It is just galvanized pipe. That is the way to go, when I get back to fixing that leak I will go that route, it looks like the way to do it right. Thanks I do appreciate it.
Jim
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
