Delta Shower Valve With Stops Adjust? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2016, 02:24 PM   #1
Delta shower valve with stops adjust?
Ok I have a Delta shower valve with the shut off stops successfully installed but now I have to turn the water back on at the stops?
How many turns? Turn all the way out? Will they fall out of hit some sort of limit??
OHMEOHMY is offline   Reply With Quote
Old 06-09-2016, 01:17 PM   #2
Rewards Points: 136
Re: Delta shower valve with stops adjust?
A picture would help. However, if it is a shower valve with built in stops, then it will either be quarter turn or turn out style. The quarter turn may not have stops, so just turn till slot is inline with pipe and should be ok. If it is a turn out style, turn the stops counter clockwise until they stop. As long as the packing nuts are secure, you should not have any problems
karin els is offline   Reply With Quote
Old 06-09-2016, 07:46 PM   #3
Meanderthal's Avatar
Rewards Points: 18
If you turn them too far they will come out. On my recent bathroom remodel I just adjusted them with the water running until turning them further didn't visibly increase the flow, then turned them back in just a bit for safety. I think there were 3 full threads visible from the top when I stopped.
I'm just a DIY guy though, and hopefully someone will come along with a better answer than mine.
Meanderthal is offline   Reply With Quote
soldering copper pipe on a shower mixing valve. Ed911 Plumbing 7 05-17-2012 09:27 AM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-12-2009 11:21 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
