Which Delta Repair Kit? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2016, 10:04 AM   #1
Rewards Points: 1,188
Which Delta repair kit?
Hi;
I have the bathtub/shower faucet shown in the photo below. The faucet drips slightly when shut off until the handle is wiggled a bit and centered in the down position. I need the repair kit, but not sure which one to buy.
The writing on top of the bezel says "Push Up Open", which is how this faucet operates.
Thanks for your help
FW
Ultrarunner2017 is offline   Reply With Quote
Old 11-06-2016, 11:46 PM   #2
Rewards Points: 38
Re: Which Delta repair kit?
Simple Delta seats and springs. Be sure you use genuine Delta parts.
SHR Plumber is offline   Reply With Quote
Old 11-10-2016, 09:12 PM   #3
Rewards Points: 463
Not sure how old that is, but modern Delta faucets have a lifetime warranty and they'll send you repair parts for free. Give Delta a call and see if yours is covered. If nothing else, they should be able to help you ID it and figure out what parts you need.
Studly is offline   Reply With Quote
Tags
delta bathtub faucet , delta repair
Replacing old delta with new delta trim, without replacing entire unit BERWYNpap Plumbing 6 02-05-2016 10:09 PM
Kohler hydrorail and Delta parts takingtoolong Kitchen & Bath Remodeling 1 05-09-2014 03:24 PM
Kohler Hydrorail and Delta takingtoolong Plumbing 0 05-08-2014 11:30 PM
drywall repair raspy Drywall & Plaster 6 07-30-2012 08:58 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
