This Delta Faucet With Built In PEX Water Lines? PICS - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By rjniles
  • 1 Post By Guap0_
Old 01-01-2018, 12:09 PM   #1
Rewards Points: 110
This Delta faucet with built in PEX water lines? PICS
Looking at the Delta Lahara centerset bath faucet. Model 2358-MPU-DST
When I looked at the specs and installation, it showed PEX water lines already attached at the top, like up inside the tube with threads that comes down from a handle, and you could cut them to length at the bottom when they connect to shutoff valves (SEE PIC).
My questions are:
1. do you have to use these lines that are supplied? Are they removable?
2. Or if you wanted to buy something like:
Fluidmaster B1F16 Faucet Connector, Braided Stainless Steel - 3/8" Female Compression Thread x 1/2" I.P. Female Straight Thread would that also work with this faucet? Meaning will the 1/2 inch end of stainless steel water line screw onto the Top thread where it attaches up under the handles?
I am used to these stainless steel types of water lines and if there should ever be a problem I can easily replace them. Whereas the PEX I have no idea what the install is, how they are attached up inside there especially at the top as the pics don't show it. Not to mention messing with cutting the PEX to length.
This Delta faucet with built in PEX water lines? PICS-fullscreen-capture-112018-125004-pm.jpg
Sandywjo is offline   Reply With Quote
Old 01-01-2018, 01:49 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Re: This Delta faucet with built in PEX water lines? PICS
The tubes are not removable. You can but the tubes to length with a utility knife. Slip the compression nut and ferrule on before you cut the tube, Those PEX tubes will last forever and you don't have to worry about changing them. They are better than the SS flex lines.
akuhn235 likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Sandywjo (01-01-2018)
Old 01-01-2018, 02:02 PM   #3
Rewards Points: 110
So if by small chance you ever developed a leak on the top end, the whole faucet would need to be replaced? I know you mentioned they are of good quality, but there are always exceptions and sometimes things happen. That is why I was afraid of any parts that were not replaceable. But I do appreciate you answering my question! Thank you!
Old 01-01-2018, 02:44 PM   #4
Peace be with you
DR P's Avatar
Rewards Points: 1,860
delta faucet guaranteed to original owner for life...
specs also say you can loop pex line into connection without cutting (comparable to your figure 1)
DST means diamond seal technology
only thing not covered is cleaning with abrasive or chemicals such as bleach
never use any solution stronger than what is on glass cleaner rags IMO
people will use tile cleaner and milder removers in shower and then come after vanity faucet with same rag... not covered
read the fine print under cleaning and care
Peace
DR P is offline   Reply With Quote
Old 01-01-2018, 02:48 PM   #5
Guapo
Rewards Points: 11,950
Sandy: they aren't as spooky as they look. I've installed at least 5 of them for customers & never had a problem or complaint.
DR P likes this.
Guap0_ is offline   Reply With Quote
Old 01-01-2018, 04:57 PM   #6
Rewards Points: 126
If you do end up doing a cut-to-length install, make sure you read the directions and the nut above ferrule is tightened adequately to angle stop! A supply line blow off and property damage could result if not properly installed!
Or...as others stated, just loop the PEX lines underneath the deck to avoid doing a cut-to-length install. The PEX is quite flexible so I'd suggest this route.
akuhn235 is offline   Reply With Quote
Old 01-01-2018, 05:06 PM   #7
Guapo
I would not recommend cutting those lines.
Tags
delta faucets , pex lines
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Faucet with attached water lines. msaeger Plumbing 5 08-15-2011 09:19 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
