Delta Bath Faucet-stuck Set Screw - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2015, 03:35 PM   #1
Rewards Points: 369
Delta bath faucet-stuck set screw
I'm trying to replace the cartridge on my Delta Monitor bath faucet but can't even get the handle off because the set screw is stuck.
Any ideas on how to get this set screw loosened and the handle off?
Zamboknee is offline   Reply With Quote
Old 10-23-2015, 04:41 PM   #2
Rewards Points: 18,350
100% sure your turning it in the right direction?
Is the Allen wrench a nice tight fit? Some are metric.
Instead of steady pressure on the wrench, give it a tap.
Old 10-23-2015, 06:58 PM   #3
Rewards Points: 369
Got it. Was a bit of trial and error until I found the right allen wrench.
Thanks!
Old 10-25-2015, 01:25 AM   #4
Rewards Points: 199
What size allen wrench did you use? I have the same faucets.
Arlo is offline   Reply With Quote
Old 10-25-2015, 11:26 AM   #5
Rewards Points: 369
Don't know. Lemme put it in the micrometer and get back to you.
Old 10-25-2015, 02:08 PM   #6
Rewards Points: 369
Size 1/8
Old 10-25-2015, 02:09 PM   #7
Rewards Points: 369
Size 1/8
The Following User Says Thank You to Zamboknee For This Useful Post:
Arlo (10-26-2015)
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 38 01-16-2018 04:07 PM
No flow from Delta Monitor 1400 faucet after reinstallation StubbornFaucet Plumbing 14 10-09-2015 11:00 PM
Tub: Faucet handle part stuck on stem NoviceHomeOwner Plumbing 4 09-20-2010 09:35 AM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 02:56 PM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 07:38 PM
