Delta 1970 Tub Faucet Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 09-15-2017, 11:20 AM   #1
Rewards Points: 22
I've read several posts but not sure how to figure out what model I have.
The faucet is leaking but I'm sure it's the handle given that the faucet is just the conduit for water to the tub. The diverter is on the faucet, not the handle.
The house was built in 1972 and all fixtures are original.
Also, I have a general knowledge of plumbing and can replace sink faucets and put in toilets but is this project something I should tackle?
If not, and I need a plumber (I have a great one but he's very busy) what can I do part wise to help before he gets here? Without turning off the water, can I remove the cover to see what's behind it? I can turn off water - it's at the street level and I have the key.
Pics attached and thanks ahead of time.
Karen
Delta 1970 Tub Faucet Leaking-2017-09-15-11.43.32.jpg   Delta 1970 Tub Faucet Leaking-2017-09-15-11.43.36.jpg
Painters1953 is offline   Reply With Quote
Old 09-15-2017, 01:06 PM   #2
Rewards Points: 6,548
Re: Delta 1970 Tub Faucet Leaking
Consider using the Delta help site for your DIY project. I've not been there but it looks promising and there is a 800 number. I'm not sure if they will allow you to send pictures.
https://www.deltafaucet.com/service-parts
Painters1953 likes this.
SeniorSitizen is offline   Reply With Quote
Old 09-15-2017, 01:14 PM   #3
retired framer
Rewards Points: 15,654
What is leaking and when?
Old 09-15-2017, 01:26 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,878
Is the leak for several hours (short time) after a shower.
It could be just a leaky diverter valve letting the shower riser drain out after a shower.
Or, it's a delta cartridge, which will be reltively easily replaceable...
Probably easiest method is to go to delta site to determine the model number, chase down at HD/Lowes/plumbing shop the new cartridge... and follow site directions for replacement of cartridge.
MTN REMODEL LLC is offline   Reply With Quote
Old 09-15-2017, 01:43 PM   #5
Rewards Points: 22
I have tried that, and I haven't heard back from them for a week.
I did find the patent #s though
2592062
3056418
Basically anti-siphon diverter valve
Old 09-15-2017, 01:45 PM   #6
retired framer
2592062
3056418
So I leaks from the tub spout when you are having a shower?
Old 09-15-2017, 01:46 PM   #7
Rewards Points: 22
Water is leaking from the faucet started out as a drip, now more of a very small but steady stream. I can pull up on the diverter handle and tie it to the handle above and most of the time the water stops dripping.
Old 09-15-2017, 01:51 PM   #8
Rewards Points: 22
See my answer to another responder about the leaking but it is constant. Delta, so far that I can tell, no longer has the find a model option on their customer support page. Their instructions say they do and I mentioned it in my comments to them.
So you're pretty confident that this would be an easy fix should I be able to tell the model?
Can I tell what kind of cartridge I need by taking off the cover/handle?
Old 09-15-2017, 01:52 PM   #9
retired framer
So when you stop it like that you are just filling the pipe up to the valve.
You should be able to remove the handle and escutcheon to see which mixing valve you have.
I would think if you tell your plumber that your 1970s delta single lever bath valve is dripping He will know what he needs to fix it.
Old 09-15-2017, 01:53 PM   #10
Rewards Points: 22
Haven't noticed that. It leaks when it supposedly is shut off.
Old 09-15-2017, 01:55 PM   #11
Rewards Points: 22
Hahaha I thought as much about filling up the pipe.
OK, another waiting game for Johnny Electric (my plumber).
Thanks!
Old 09-15-2017, 01:58 PM   #12
retired framer
The Following User Says Thank You to Nealtw For This Useful Post:
Painters1953 (09-15-2017)
Old 09-15-2017, 02:22 PM   #13
Rewards Points: 1,950
http://www.homedepot.com/p/Delta-Rep...3614/100147397
Get the all three pack.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 09-15-2017, 02:33 PM   #14
Rewards Points: 22
I want that handy little tool!
Nealtw likes this.
Old 09-15-2017, 02:59 PM   #15
Rewards Points: 22
Thanks to everyone who helped me today. I've very good at following up and will let you know the outcome!
Leaking Faucet: Single Handle Shower Head chicy724 Plumbing 27 03-03-2015 05:43 PM
Delta faucet leaking after repair & new parts KarenNoelle Plumbing 1 01-28-2015 07:01 AM
Repair Instructions for Delta Kitchen Faucet BigJim Plumbing 2 04-07-2011 10:36 AM
Need help removing Delta bathroom faucet Mr_allthumbs Plumbing 6 06-01-2010 04:50 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
