Decent Bathtub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By akuhn235
Old 03-24-2018, 06:23 PM   #1
Rewards Points: 64
Decent bathtub faucet
I have delta bronze tub faucet set and the faucet insides are plastic. The diverter half ass works. Does anyone make a good quality spout\diverter anymore?
rutledj is offline   Reply With Quote
Old 03-24-2018, 06:26 PM   #2
ZTMAN's Avatar
Rewards Points: 628
Re: Decent bathtub faucet
They are guaranteed for life. Call Delta, get some replacement parts , and you will be good to go.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
Ghostmaker (03-24-2018)
Old 03-24-2018, 06:55 PM   #3
Rewards Points: 64
How do you replace a diverter? Or just the whole spout?
Old 03-24-2018, 09:25 PM   #4
ZTMAN's Avatar
Rewards Points: 628
Whole new spout.
Old 03-24-2018, 09:34 PM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
guaranteed to original owner only... nowadays all faucets have plastic
innards where they can... & tub diverters wear out; how old is yours?
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 03-24-2018, 10:00 PM   #6
Rewards Points: 281
Peace
A couple or more years ago, when I emailed Delta for replacement seats, springs and cartridges, I just mentioned the model name of the faucet. They didnít ask for proof of purchase.
Druidia is offline   Reply With Quote
Old 03-24-2018, 10:14 PM   #7
Rewards Points: 64
Mine is about 6 years old. What should the life of these be? I have no idea the model.
Old 03-31-2018, 08:43 PM   #8
Rewards Points: 126
More than 6 years, IMO. If it's leaking excessively out the spout outlet when you are trying to divert the water to showerhead, the seal within the tub spout is most likely worn. Unfortunately, this isn't a replaceable seal and you will need a new tub spout. This seal is a rubber seal that wears naturally. Dynamic rubber seals wear with use (friction). IIRC Delta aand most USA-made plumbing products are tested and certified to ASME A112.18.1. You can dig through it for testing requirements or if you're looking to take an afternoon nap.
Contact Delta and they will help you locate the model number of tub spout and should get you one shipped out under their warranty.I'd suggest you try digging through Delta website to locate the model number as this will quicken your time with customer service.
While plastics tub spouts may feel cheap, they are not prone to electrochemical attacks (i.e. rust, dezincification, corrosion) which a lot of metal plumbing components fail from. Most sealing mechanisms within tub spouts that I'm aware of rely on dynamic rubber seals which are prone to wear (and furthermore leaks out the tub spout outlet) by design regardless if the tub spout is metal or plastic.
Cheers,
AK
Mike Milam likes this.
akuhn235 is offline   Reply With Quote
Bathtub Faucet - Hard Line or Flex Line? ddawg16 Plumbing 7 05-17-2014 02:24 PM
How to fix the bathtub faucet dripping? compiler Plumbing 10 03-07-2013 09:17 PM
Bathtub faucet won't stay depressed to direct water to shower head ferrugia Plumbing 13 02-27-2013 09:39 PM
Bathtub faucet leaking majas Plumbing 3 09-25-2011 10:04 AM
Bathtub faucet leaks from screw hole under faucet. Debmmill Plumbing 3 02-13-2011 06:43 AM
