Damaged Concrete At Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2020, 01:12 AM   #1
Rewards Points: 6
Damaged concrete at closet flange
Hi.
I pulled up my half bathroom's linoleum flooring to replace it with vinyl. The floor is concrete because we are at the bottom floor of a condo building. With the toilet removed, I can see that the hole in the concrete where the closet flange is seems to have a gap where concrete has broken away past the diameter of the flange and sewer pipe.
I was about to start putting down self leveling concrete on the floor but would like to know if I should repair this gap and if I should replace the closet flange?
If so, what method and material should I use for repairing the gap?
Just for extra info, the closet flange is 4" x 3" plastic and seems to be glued to the outside diameter of another plastic pipe, which is then on top of the sewage pipe.
Attached are pictures to show what I mean.
Damaged concrete at closet flange-toilet-flange-2-.jpg   Damaged concrete at closet flange-toilet-flange-3-.jpg   Damaged concrete at closet flange-toilet-flange-5-.jpg   Damaged concrete at closet flange-toilet-flange-6-.jpg
pgaggini is offline   Reply With Quote
Old 05-26-2020, 10:17 AM   #2
dj3
Rewards Points: 1,966
Re: Damaged concrete at closet flange
My questions are: - Does the crack, or hole go all the way to the dirt?
- Is the drain stable and secured?
Sealing the hole may be fine.
dj3 is offline   Reply With Quote
Old 05-26-2020, 10:21 AM   #3
Rewards Points: 164
How far does the hole go down? Can you stick a tape measure down there and repost the pic?
Biscuits is offline   Reply With Quote
Old 05-31-2020, 02:09 AM   #4
Rewards Points: 6
Hi again. Thanks for getting back to my question and sorry for the late reply; I have only been working on the renos at the weekends.
I removed the top of the flange because it was leaning slightly.
The flange is a 4"x 3" flange glued onto the outside diameter of a 3" pipe which seems to be hose clamped to the metal sewage pipe.
I only managed to get the top lip of the flange off but once I done this it revealed that there was gaps all round the flange.
Attached are photos to help show what I'm describing.
Does anyone have info for what type of how I will remove the rest of the flange and once I replace, what material to use to fill the gaps and the method.
Thank you.
Damaged concrete at closet flange-20200530_193700.jpg   Damaged concrete at closet flange-20200530_194831.jpg   Damaged concrete at closet flange-20200530_194841.jpg   Damaged concrete at closet flange-20200530_194852.jpg
Old 06-02-2020, 02:50 PM   #5
Rewards Points: 242
HOW did you remove the top flange? Unless thats a clean piece of pvc that you can glue a new flange onto, you may have to break up some cement so you install a new riser to glue a new flange onto. If the pipe was stable, what possessed you to remove the top of the flange? Being a little off level isnt a big deal. The wax makes up for it.
bruceb3 is offline   Reply With Quote
Old 06-02-2020, 03:37 PM   #6
Rewards Points: 164
That riser can be cleaned up.
Regarding the concrete: I'd pack the hole full of mortar. And would even consider wrapping the riser with a piece of plastic, although probably not necessary.
Grout would probably be fine too.
Tags
bathroom , closet flange , concrete , plumbing , toilet
