Cutting NG Piping - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2015, 06:56 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Cutting NG piping
Greetings:
I'm in the process of remodeling our 100 year old money-pit. This house was originally built as a 2-flat and we are converting it into a single family home.
Some years ago, someone ran two 1/2" black iron pipes across and perpendicular to the tops of the floor joists in the first floor. None of the original framing was notched thankfully as the planks that were used for the subfloor were simply laid on either side of the pipes and the T&G hardwood finish floor was applied over atop 1/4" sleepers. These lines provided NG to fireplace inserts that were removed prior to us buying the property.
The old plank subfloor was removed and I mended all defects in the floor joists. My intent is to lay down a new subfloor consisting of T&G 4x8 sheets and accordingly, the gas lines need to be removed (they serve no purpose as the lines for the gas stoves are run separately). The plan is to shut off the gas, remove the piping and plug the existing fittings where they connect.
What is the best way to cut each of the pipes? There is no way to vent these lines and I am concerned about cutting into them using a reciprocating or hacksaw, i.e. anything that may create a spark. I would simply use a wheel-based pipe cutter but unfortunately, the lines are run so close together that there would be no way to rotate it around either separately (and the tie in point to gas lines occurs between two floor joists).
Thanks in advance for the help!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 01-31-2015, 07:06 PM   #2
Rewards Points: 1,942
saws all with hack saw blade once gas is off.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (01-31-2015), gregzoll (01-31-2015)
Old 01-31-2015, 07:15 PM   #3
Rewards Points: 566
Thanks for the reply Ghost. So I needn't worry about any remaining gas that is in the lines once it is shut off? Am I being overly concerned about a spark igniting any remaining gas?
Thanks,
J
Old 01-31-2015, 07:15 PM   #4
Rewards Points: 582
sawzall with metal blade or hack saw.....either one is fine ..don't worry about venting line...just make sure gas is off....and mentioned...
Old 01-31-2015, 07:17 PM   #5
Rewards Points: 6,484
Depending on the space, a 3 wheel cutter may work. Might pay to check with a tool rental for their smallest. If the pipe cutter will work you'll like it much better.
Old 01-31-2015, 07:56 PM   #6
Rewards Points: 6,652
You could cut it even with the gas on. There would not be enough air/gas mixture to create an issue.
What you smell when you shut the gas off, is the additive that gives it a smell. If you have a standing pilot water heater or furnace, there is actually very little gas left in the line when you turn off the valve at the meter.
Old 01-31-2015, 08:59 PM   #7
Rewards Points: 566
Originally Posted by gregzoll
You could cut it even with the gas on. There would not be enough air/gas mixture to create an issue. What you smell when you shut the gas off, is the additive that gives it a smell. If you have a standing pilot water heater or furnace, there is actually very little gas left in the line when you turn off the valve at the meter.
Thanks, Greg and others. When I had to modify the gas piping to the upstairs kitchen, I lit a burner on the stove prior to shutting off the gas to burn up whatever was left in the line before I went at it with my Sawsall.
Thanks again,
Jimmy
Old 02-01-2015, 03:41 AM   #8
Rewards Points: 404
Jimmy
Why cut them? Why not unscrew the sections which are in your way, then plug the last fitting (or cap the last nipple) ?
A Squared is offline   Reply With Quote
Old 02-01-2015, 07:04 AM   #9
Rewards Points: 582
always turn gas off when working on pipes ...no exceptions.....
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Javiles (02-01-2015), MTN REMODEL LLC (02-01-2015)
Old 02-01-2015, 08:01 AM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Gee Ben you take the fun out of everything don't you.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following 2 Users Say Thank You to Javiles For This Useful Post:
ben's plumbing (02-01-2015), gregzoll (02-01-2015)
Old 02-01-2015, 01:49 PM   #11
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,870
Greg..............Not me.....
MTN REMODEL LLC is offline   Reply With Quote
Old 02-01-2015, 01:59 PM   #12
Rewards Points: 582
really don't know why anyone would tell a homeowner you could cut a gasline without turning it off 1st.... again no telling what you may hear..
The Following User Says Thank You to ben's plumbing For This Useful Post:
djlandkpl (02-01-2015)
Old 02-01-2015, 02:06 PM   #13
Well.... I've heard about guys welding/repairing their automotive gas tank...
(Think I read about it in the obits)....
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 02-01-2015, 02:34 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 258
I'm sure the plumbers here have some fun gas stories but I won't share mine-- might end up making the Darwin Award headlines......
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 02-01-2015, 06:37 PM   #15
Rewards Points: 566
Haha! Yeah, I totally agree. Fortunately, I tend to err to the cautious side when working with NG as I am not a plumber. In fact, I always turn off the gas at the meter before working on that system and I mentioned in my OP that shutting off the gas was indeed part of the plan.
I assumed that due to a lack of oxygen in the line, I was probably OK chopping away at the pipes (again, with the gas shut off). But again, I don't do this every day and therein, I always like to get input from the professionals (and I've spent enough time on this site to get a good feel for who those people are).
At any rate, I shut off the gas today, cut the lines, unscrewed the pipes and fittings and installed plugs in the existing tee's (using yellow PTFE tape).
Thanks for all of the comments, guys. I always appreciate the advice.
J
The Following User Says Thank You to BigJimmy For This Useful Post:
Do you ENJOY cutting in? DrHicks Painting 66 01-29-2014 09:22 PM
Pex or Copper piping? for apartment or house crayola110 Plumbing 13 11-16-2013 08:18 PM
Growing A Willow From A Cutting...How/When To Prune? JL-KA Landscaping & Lawn Care 2 10-09-2013 04:24 PM
Tips for Cutting Baseboards and Door Trim hellothere123 Carpentry 25 10-20-2012 09:40 AM
Galvanized piping and Rough in valve geomeo Plumbing 5 10-13-2012 10:11 PM
