Cutting Cast Iron Waste Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2015, 07:04 PM   #1
Rewards Points: 28
Cutting cast iron waste pipe
What is the best way to cut a cast iron waste pipe? We were trying to remove a broken flange from the pipe that is over 70 year old. In doing so the top rim of the pipe chipped about a 3" long by 1 " deep. I bought a PVC compression flange that is long enough to go past the chipped section of pipe but I need to cut around the pipe about an inch to even it out. A mini-hacksaw is cutting but extremely slowly.
Any advice would be appreciated?
Thank you,
Ken
kxweil38 is offline   Reply With Quote
Old 03-08-2015, 07:09 PM   #2
Rewards Points: 582
picture of what you have will help.....I use castiron snapper ...but you could also use a sawzall with the right blade...
Old 03-09-2015, 09:23 AM   #3
Rewards Points: 3,209
I've only done it once. Angle grinder worked.
mathmonger is online now   Reply With Quote
Old 03-09-2015, 09:50 AM   #4
Rewards Points: 28
Thanks to all for the replies! While not the best we ended up using a mini hacksaw to cut down into the top of the pipe down every 1/2" to the level of the original chip and snap it off with pliers. We were able to use a compression flange to fit into the pipe and it sits level and on the tile floor and the compression adjusting ring is well below the top of the pipe..
The Following User Says Thank You to kxweil38 For This Useful Post:
ben's plumbing (03-09-2015)
where to buy a short length of 4" cast iron waste pipe diy888 Plumbing 12 03-14-2015 06:50 AM
Cast Iron Pipe Type - SV or XH northerndave Plumbing 10 04-01-2013 07:32 PM
Rusted at thread cast iron pipe handyman99 Plumbing 5 01-24-2012 11:13 PM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
