Culligan Tor - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2015, 05:32 PM   #1
Rewards Points: 4
Culligan tor
My Culligan medalist will not display the tor after the tod during setup. It used to regen at 2:00 am. Now it does it at random times and I can't get the tor to display so I can reset it.
chiko is offline   Reply With Quote
Old 06-19-2015, 08:55 PM   #2
Rewards Points: 18,976
Needs to be moved to plumbing.
Old 06-20-2015, 11:03 AM   #3
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Will look it up to see if a reset will work or your going to need to replace the board.
Some times a board needs a reset or restart and all is good , then some times it is replace time for the board.
If you do have to replace the board some times you can find a good used one on an Auction site or you could go with new.
Akpsdvan is offline   Reply With Quote
Culligan Softener Maintenance Scully Plumbing 7 07-30-2013 11:59 PM
Well Debris and Culligan Softener Scully Plumbing 5 06-18-2012 09:16 PM
Culligan Aqua-Cleer replacement filters - DIY? liberty79 General DIY Discussions 6 03-04-2012 10:48 AM
Culligan water softener not working (pics) Perm Plumbing 46 09-14-2011 12:29 AM
Rebedding a Culligan Cullar carbon filter scrupul0us Plumbing 0 08-24-2011 05:41 PM
