Culligan Medalist Series Water Softener Drain Leak - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Akpsdvan
Old 04-11-2017, 01:56 PM   #1
Rewards Points: 8
Culligan Medalist series water softener drain leak
I have a slight drip-drip-drip coming out the top drain hose through the pvc pipe when the unit is in non-gen (normal) mode. Everything else works fine. Does the whole control valve need rebuilding, or is it just a matter of replacing the drain elbow backwash restrictor (part #8)? Thanks!
Culligan Medalist series water softener drain leak-img_1959.jpg   Culligan Medalist series water softener drain leak-img_1960.jpg
mrsnak is offline   Reply With Quote
Old 04-11-2017, 02:37 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,368
Re: Culligan Medalist series water softener drain leak
Can you indicated on the picture where the leak is?
Most of them have rubber washers that are serviceable.
Old 04-11-2017, 02:44 PM   #3
Rewards Points: 8
The leak is internal. Water goes out through the elbow, through PVC, and drains into the same downspout pipe the washer next to it uses. I can hear the water drip inside the downspout. Pretty sure water is only supposed to flow out that fitting during the re-gen process.
Old 04-11-2017, 06:02 PM   #4
Then that is a valve body issue. They are rebuildable as well if memory serves me.
Old 04-11-2017, 08:04 PM   #5
Rewards Points: 8
Thanks!
I'm just trying to figure whether or not to try it myself. Not sure what part might be failing, which is why I posted here. Lot of parts in that body. Culligan is $130 just for a service call. Parts on top of that.
Old 04-12-2017, 11:24 AM   #6
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
If you are very handy and can look at that one drawing and figure out how to take it apart and put it back then get the seal pack assembly and replace the main seal pack as there is at least one seal that is bad if not two.
Most Good service techs could have it done with in an hour, I know that I could.
You might take 2 hours and there is nothing wrong with that.
Windows on Wash likes this.
Akpsdvan is offline   Reply With Quote
Old 04-12-2017, 12:16 PM   #7
Rewards Points: 8
Good idea - I'll see if I can get a seal kit and try it. Nothing to lose!
Thanks!
Installed water softener now Delta 1700 Series now pressure balance not working. Jim F Plumbing 4 03-31-2015 09:57 AM
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
culligan water softener troubleshooting kristijill Plumbing 1 04-18-2011 01:33 AM
Culligan Medallist Series 45 water softener keithk Plumbing 3 08-25-2010 12:29 PM
