Creek To Pump To Plain Old Garden Hose - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2016, 03:00 PM   #1
Rewards Points: 4
Creek to pump to plain old garden hose
Hey there y'all,
I have been through so many forums, talked to DIYers, pump hotlines, you name it, but I can't get an answer to this question. There are a couple of threads here that start out the same way, but never land up answering the question.
Bought a place where the last chap would've had the setup I'm looking for, but he took the pump with him which is where's I'm stuck.
And yes, before it comes up, I have permission to use the creek for this purpose.
It goes like this:
Creek to shed with pump housing:
Run: 150 ft
Rise: about 10 ft
Intake hose (already run the 150 ft) is 1" ID ABS with screened fitting on the end (no foot /check valve).
Output is a plain old 3/4" garden hose - also about 150 ft. He's got it buried in the lawn over to where the veggie gardens are, and a pond that he used to top up now and again (so I'm told).
The housing is in no way big enough to have held a pump and a tank, so best that I can figure is that it just pumped water through.
Any ideas on what pump I need to get this set-up going again? I got lots of suggestions for hooking it up to a fancy sprinkler system but all I want to do is hook it up to the plain old garden hose.
Thanks much.
jayzee is offline   Reply With Quote
Old 06-06-2016, 03:11 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,670
Re: Creek to pump to plain old garden hose
He may have had something like this, but it still needs a check valve at the bottom end.
http://www.canadiantire.ca/en/pdp/ma...3593p.html#srp
The Following User Says Thank You to joed For This Useful Post:
jayzee (06-07-2016)
Old 06-06-2016, 03:15 PM   #3
Lord of Slums
Rewards Points: 1,974
yep, foot valve or you lose your prime everytime. Intake hose must be ridged. Where are you mate?
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
jayzee (06-07-2016)
Old 06-06-2016, 07:06 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,776
A centrifugal pump like shown will handle the lift but you might have problems because of the intake length. It will create friction - a larger diameter intake might help. As mentioned, you will need a foot valve to maintain prime. Another problem may be the distance of your discharge with that suggested type of pump it's only advertised for pumping 25' and I don't know if you will be able to find any that will pump 150'. In either case, you will want a pressure tank.
lenaitch is online now   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
jayzee (06-07-2016)
Old 06-06-2016, 10:17 PM   #5
Lord of Slums
http://www.harborfreight.com/1-hp-sh...gph-69302.html
The Following 2 Users Say Thank You to mj12 For This Useful Post:
jayzee (06-07-2016), plumberinlaw (06-06-2016)
Old 06-07-2016, 08:08 AM   #6
Rewards Points: 4
mj12 - the fella already has the hose laid out - smooth though, not ridged. Do you think I oughta replace it?
Other than drainage tubing, not sure I've seen ridged (other than what you can buy for ponds - $$$)
In Ontario, Canada. I see joed is here too, based on the CTC link.
Old 06-07-2016, 10:19 AM   #7
Oso954's Avatar
Rewards Points: 1,622
25ft is the max vertical lift (suction) of that pump, not the horizontal distance it can pump.
Oso954 is online now   Reply With Quote
Old 06-07-2016, 10:16 PM   #8
Lord of Slums
i would use the piping that is there for now. That pump I posted has the pressure tank built in.
jayzee (06-08-2016)
Tags
creek , garden hose , lake , pump , watering
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 05:15 AM
Cross threaded garden hose hubbard Plumbing 7 10-01-2012 07:47 AM
Repairing Garden Hose Connection cl6120 Plumbing 9 09-12-2012 09:20 AM
Pressure washer blew the garden hose tucker0104 Tools 6 05-29-2012 06:51 PM
My sump pump hose freezes every winter. How can I prevent this? Fred311 Plumbing 3 01-28-2010 12:15 AM
