Cranking Up Hot Water Temp? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2016, 03:08 PM   #1
Rewards Points: 3,209
I have to launder a bunch of really dirty stuff. Is there any reason I shouldn't crank the temperature on my hot water heater all the way up? Half of me thinks that's completely nuts and something would surely explode, but the other half of me thinks it must be fine or they wouldn't put those settings on the hot water heater. I've got a 60 gallon natural gas tank that is only a few months old. I figure it would just take a few hours to heat up and then I could put it back. What do you think?
mathmonger is offline   Reply With Quote
Old 01-05-2016, 03:10 PM   #2
Also, my machine sometimes squirts in occasional blasts of cold water even when I have it set on hot. I think maybe it has some kind of automatic temperature control. So maybe turning up the hot water heater wouldn't actually do anything.
Old 01-05-2016, 04:03 PM   #3
Rewards Points: 3,486
No need to crank it up, imo.
Most washing machines do squirt a little cold water in during cycles.
jmon is offline   Reply With Quote
Old 01-05-2016, 04:04 PM   #4
Rewards Points: 3,436
You can crank up the water heater temperature a reasonable amount without danger of explosion but the water at the shower and faucets could be dangerously hot.
I would crank up the temperature only a little or not at all and use a little more detergent (and also run an additional rinse half-cycle by manually turning the machine control knob after the first cycle finishes completely).
If your washing machine hookup has separate hot and cold knobs on the wall you might try turning the cold knob all the way off as the washer fills for the first time. (Almost all washers add some cold water for the rinse and may or may not stop the cycle halfway and wait if you don't turn the cold back on.)
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 01-05-2016, 04:29 PM   #5
Rewards Points: 1,950
Let the stuff soak in the machine with good detergent.
Ghostmaker is online now   Reply With Quote
Old 01-05-2016, 07:17 PM   #6
I recently had great success on some impossible set-in yellow stains on a pillow case using a boil wash. Three parts hydrogen peroxide to one part baking soda and boil it on the stove. It worked like a monster. It worked better than a 100% bleach bath. That's what got me interested in the high temps.
Old 01-05-2016, 08:35 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,308
Ayuh,.... I've been washin' my clothes in cold water for 40 years,....
Alot less shrinkage,....
Old 01-05-2016, 10:08 PM   #8
Rewards Points: 1,956
Throw in a quarter-cup of TSP, Trisodium Phosphate. Home Depot.
ChuckF. is offline   Reply With Quote
Old 01-05-2016, 11:47 PM   #9
Rewards Points: 2,906
The only real danger in turning up the thermostat on your water heater is that you greatly increase the risk of scalding. Most water heaters will come from the factory with the thermostat set at 120 deg. F. I keep mine set at 130 deg. F. If you have small children or mentally challenged people in your family, it's best to keep your water heater temperature down so that they don't accidentally scald themselves. If it's all mature responsible adults in your household, then I'd say go for it. Just be more careful with that hotter water.
The higher temperatures WILL shorten the lifespan of your water heater a bit. That's because the lifespan of a water heater is largely determined by the lifespan of the porcelain enameled tank inside it, and the lifespan of that tank is determined by the lifespan of that porcelain enamel coating on the inside of the tank (which is similar to the porcelain enamel coating on a steel bath tub). The lifespan of that coating is largely determined by the cumulative "thermal shocking" the coating receives. The higher the temperature of the water in the tank, and the greater the drop in temperature when new cold water comes in to replace hot water drawn out, the greater the thermal shocking the porcelain enamel coating receives, and the sooner it will crack and expose the metal walls of the tank to water, and hence corrosion. This is why a larger tank that has smaller temperature drops will last longer than a smaller tank with larger temperature drops.
You don't have to worry about your tank exploding. It will be fitted with a Temperature and Pressure relief valve that will open if EITHER the temperature or pressure inside the tank become too high. I haven't had a gas fired water heater in nearly 10 years now, but if I recall correctly, the T&P Relief valve will open at either 200 deg. F or 150 psi, whichever comes first.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 08:13 AM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
