CPVC Stainless Drop Ear To Brass Pipe Nipple? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By chandler48
  • 2 Post By joecaption
Old 10-22-2017, 09:07 PM   #1
Rewards Points: 20
CPVC Stainless Drop ear to Brass pipe nipple?
Hi,
I noticed the drop CPVC drop ear fittings are now stainless and not brass anymore?
CPVC Stainless Drop ear to Brass pipe nipple?-nibco-elbows-c470735sihd12-64_1000.jpg
My questions is: Can I use a brass pipe nipple like this and just teflon tape and pipe dope into the stainless?
CPVC Stainless Drop ear to Brass pipe nipple?-sioux-chief-nipples-934-20201-64_1000.jpg
Or does the 2 different metals cause a problem ?
The all plastic treaded drop ears I feel like will leak over time.CPVC Stainless Drop ear to Brass pipe nipple?-plastic.jpg
I like using the drop ear connectors for stubbing out the brass nipples under vanities and toilets for a firm pipe to attach shutoffs to
Thanks!
joew623 is offline   Reply With Quote
Old 10-23-2017, 05:54 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,734
Re: CPVC Stainless Drop ear to Brass pipe nipple?
The solid CPVC drop ears will tend to crack over time from movement of the tube. Placing stainless and brass together won't cause problems like iron and brass would. Even though they are dissimilar materials, no electrolysis will take place. I prefer using Rector seal than teflon tape as it seems to preclude small drips.
Bondo likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-23-2017, 07:48 AM   #3
Rewards Points: 18,990
No way would I count on a plastic drop leg!
Use a solid brass one instead.
Bondo and chandler48 like this.
Ghostmaker (10-23-2017)
Which kind of pipe...What size? maddog1 Plumbing 25 08-24-2015 06:13 PM
Chandelier Threaded Brass Pipe PrettyBird Electrical 3 09-24-2014 07:29 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
