CPVC - Full Port Ball Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2015, 09:59 PM   #1
Rewards Points: 272
CPVC - full port ball valve?
Do they make full port ball valves in CPVC or will I need to use the brass ones?
I'm wondering if they makes the below as a full port valve, hoping it might save me a few buck ... not just of the cost of the valve, but the fitting I would need if I had to use the brass ones with CPVC.
Thanks!
crabjoe is offline   Reply With Quote
Old 12-18-2015, 05:13 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Do yourself a favor and do not use CPVC valves, they are junk. Use a brass valve and 2 CPVC male adapters.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 12-18-2015, 06:17 AM   #3
Rewards Points: 3,130
Have to agree. If the valve will not be operated very often (I have a couple of them) then CPVC would probably work. But otherwise, use brass. My main plumbing shutoff is in the crawl space. It's brass. But for more convenience in the case of a big plumbing leak or, say, replacing a faucet, I put in a CPVC valve in my laundry room, next to the water softener. In seven years, I've operated it exactly twice.
Old 12-18-2015, 08:07 AM   #4
Rewards Points: 272
Guys thanks for the info, but what I'm trying to do is see if they make 1" full port CPVC valves. When ever I see CPVC valves, unlike brass valves, they're don't say whether they are full port or not.
Can anyone tell me if they a 1" CPVC full port valve is available?
Old 12-18-2015, 08:15 AM   #5
Rewards Points: 5,466
http://www.nibco.com/Industrial-Plas...ule-80/Valves/
Old 12-18-2015, 08:21 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
http://www.grainger.com/product/GRAI...26s_pp%3Dfalse
Cant see it any cheaper than brass.
Repair Ball Valve hubedori Plumbing 5 04-08-2015 02:25 AM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Replacement drain cap for ball valve mpnret Plumbing 1 02-21-2012 11:43 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
