CPVC Couplings And Fittings In NPS? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2016, 03:44 PM   #1
Rewards Points: 18
CPVC couplings and fittings in NPS?
I had to cut my condensate drain line in the attic, coming out of my air handler. It's 3/4 CPVC in NPS. I was looking for CPVC couplings, and I can only find them in CTS. Does anyone make them in NPS, or am I supposed to use PVC couplings? It can get up to 150 degrees in my attic, so are PVC couplings and fittings going to be ok? I assume the answer is yes since the HVAC guy who last serviced it used PVC couplings, but I want to make sure.
Thrawn is offline   Reply With Quote
Old 06-16-2016, 06:18 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Re: CPVC couplings and fittings in NPS?
CPVC is sized to CTS. I don't know what NPS is, do you mean IPS? If someone used PVC on CPVC, it is wrong. Use CPVC couplings.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 06-16-2016, 06:22 PM   #3
Rewards Points: 18
Nope, NPS. I'm just learning about different types of pipe and sizing. Is this not correct? http://pvcpipesupplies.com/cpvc-vs-pvc
CPVC couplings/fittings I find are all CTS, and won't fit?
Old 06-16-2016, 06:57 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
If CPVC coupling will not fit, you don't have CPVC. Condensate drain lines are usually PVC and most likely what you have.
Old 06-16-2016, 07:01 PM   #5
Rewards Points: 18
Ok, thanks. It's off-white, and the couplings are white. I read on that website that PVC is always white, and off-white is CPVC.
Cpvc to pex dakota11 Plumbing 2 02-15-2012 08:33 PM
Carcinogens in brass fittings? cliffspielman Plumbing 7 02-06-2011 01:50 AM
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
using couplings on 1/2 galvanized pipe riverjamie Plumbing 0 05-22-2010 09:50 AM
PVC slip couplings ponch37300 Plumbing 6 04-03-2009 10:02 AM
