Cpvc - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2016, 05:26 PM   #16
Rewards Points: 1,866
Re: Cpvc
Make real sure he that the CPVC is secured every 32 inches.
Old 05-02-2016, 06:50 PM   #17
Rewards Points: 850
Re: Cpvc
ok, but im leaning towards the pex
hotrod351 is offline   Reply With Quote
Old 05-03-2016, 05:00 PM   #18
Re: Cpvc
Same for pex. And also reseal the bottom of the mobile home.
Old 05-08-2016, 06:34 AM   #19
Rewards Points: 850
Re: Cpvc
all done. two men = 9 hours, and yes they knew what they were doing. also moved my gas heater to laundry room and extended the gas line. havent had this volume for many, many years. knew it was going to have to be done for a long, long time. the only problem they had is with the 60 year old Sterling shower connections. think they have it whipped.
The Following User Says Thank You to hotrod351 For This Useful Post:
TheEplumber (05-08-2016)
Water heater connections to existing CPVC mrxsme Plumbing 2 01-28-2014 07:20 PM
Cementing 1/2 inch CPVC in crawlspace steve3847 Plumbing 6 12-16-2012 07:04 AM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
Water Heater Connections (CPVC) Pittsville Plumbing 16 01-21-2012 08:02 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
