Coupling Does Not Fit On Old Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2015, 07:35 PM   #1
Rewards Points: 119
Coupling does not fit on old copper pipe
I bought some 1/2" coupling to repair a leak with a current copper pipe.
However, I can't fit the coupling over the pipe.
Any suggestions on fixing this?
suncowiam is offline   Reply With Quote
Old 05-08-2015, 08:34 PM   #2
dannyoung85's Avatar
Is the existing pipe hard or soft copper?
dannyoung85 is offline   Reply With Quote
Old 05-08-2015, 08:59 PM   #3
Rewards Points: 18,974
Was it leaking because the old pipe split from freezing?
100% sure you used a dull cutter or used to much pressure and distorted the pipe or left a burr?
Old 05-08-2015, 10:36 PM   #4
Rewards Points: 119
I grinded it with sand paper and now it fits fine...
Old 05-08-2015, 10:44 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
Yep.... If it's not distorted.... sand it down.
(A couple of years ago, I got some new copper that was slightly oversize... maybe some chinese machine got slightly out oif tolerance.
Neither new fittings, or old fittings , would fit this new pipe. Just sand it.. never had it happen before, never after.)
MTN REMODEL LLC is offline   Reply With Quote
soft copper pipe issues fred54 Plumbing 7 04-02-2013 05:53 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 08:44 PM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 05:02 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
