Correct Plumbing From Well Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2016, 09:59 AM   #1
Rewards Points: 740
Correct plumbing from well tank
I have heard conflicting claims about what plumbing is necessary from the well pressure tank to the house. Do I have to use galvanized pipe or can I use PEX, Poly Pipe? My tank is in the crawl space.
crescere is offline   Reply With Quote
Old 11-19-2016, 11:02 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Re: Correct plumbing from well tank
Ayuh,..... My well starts at the bottom with the submersible pump to 1" black ploy pipe up to the well head to the switch, 'n pressure tank,....
It then splits, 1 line(black poly) goes just under 100' to the house, the other line(black poly) goes to the garage/ office,....
In the house, it comes into another pressure tank, 'n then through-out the house with a mix of gal. pipe, copper pipe, 'n pex,...
In the garage/ office it goes to 'bout center, 'n pops up as a frost-proof hydrant, which is hose connected to the copper plumbin' through-out,...
If I were to do it over again, black poly pipe goes in the ground, 'n pex goes in the buildin's,....
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Septic Tank Plumbing Vents Covered With Filters in Basement jskirwin Plumbing 4 12-07-2009 12:31 AM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
