Is This The Correct Forum? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2016, 03:00 PM   #1
Rewards Points: 2,238
Is this the correct forum?
Do we post lawn irrigation issues here or somewhere else?
Thank you.
tstex is offline   Reply With Quote
Old 05-12-2016, 03:07 PM   #2
Rewards Points: 3,220
Re: Is this the correct forum?
Depending on what your question is, maybe someone here can help.
jmon is online now   Reply With Quote
Old 05-12-2016, 03:22 PM   #3
ok. I have two:
1. First, a lot of my sprinkler heads are not spraying evenly bc they were installed crooked. in order to fix these, I am going to have to dig out dirt around the body of the spray head, then level them by placing sand around the body until the cap is level. Is there a better way to do this?
2. When the irrigation system was running at 5am, my truck went off the driveway just enough to break off the riser. Is there anything special about pulling off and out the body and re-installing a new one?
Note, I will take the old one w mean and the riser/spray head so I make sure I get the exact replacement.
Thank you very much,
tstex
Old 05-12-2016, 04:30 PM   #4
1) also check and make sure head is free of sediment. Some vinegar and water or clr should help.
2) make sure they are no retainer clips that can prevent them from coming off. Pretty straight forward, instructions will be right on package.
Old 05-12-2016, 04:53 PM   #5
Thank you Jmon...
When you refer to the head, are you referring to where the riser and screen are located?
Old 05-12-2016, 07:36 PM   #6
You are welcome.
Yes, sometimes they can get clogged up with sediment and effect the spray pattern. I don't know what type of nozzel head you have. A picture would help.
The one I'm thinking of is the type that unscrews or has a retainer clip for easy removal and cleaning.
Old 05-12-2016, 08:08 PM   #7
Here's a diagram of what I typically have, w the body and riser varying in size:
article:
Typical Modern Pop-Up Sprinkler Head
Does this help? Thanks
Old 05-13-2016, 07:34 AM   #8
Rewards Points: 260
You don't need to put sand around the head when releveling. Dig up the head, level and refill.
If you can find the exact replacement pop up, you can leave the body in the ground. Loosen the cap and swap the guts.
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
tstex (05-13-2016)
Old 05-13-2016, 08:27 AM   #9
Thanks Dan - That sounds like a plan...tstex
Appreciate everyone's help
The Following User Says Thank You to tstex For This Useful Post:
jmon (05-13-2016)
How do I pick the correct coaxial cable? fwmcbigfoot Home Theater 1 12-30-2008 09:45 AM
New Look Jims69 Site Help and Suggestions 6 06-19-2006 02:00 PM
