Copper Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2013, 10:55 AM   #1
Rewards Points: 225
copper pipes
Replaced drywall ceiling that has hot and cold copper pipes notched into the bottom of the ceiling joists. Went to install new drywall and pipes are below the ceiling joists. Not sure if it was like this before. The pipes move some but not enough to get past the ceiling joist.
1) Does the hot water pipe get hot enough that it should not touch the wood or drywall? Also, cold water pipe ok to touch wood and drywall?
2) Reworking the copper pipes would be a fair amount of work. Can the drywall be put back up touching the pipes? Will the pipes develop a leak?
Thanks.
gt1935 is offline   Reply With Quote
Old 12-28-2013, 11:03 AM   #2
Rewards Points: 18,988
Got a picture?
Floor joist should not have been notched.
Pipes should not be touching the sheetrock.
Going to need to add nailing plates and shim down the joist.
Another way is to replace the copper with Pex and drill holes in the joist to run it through.
Old 12-28-2013, 11:22 AM   #3
dannyoung85's Avatar
My basement was built with the copper water lines notched in the joists and sheet rocked over just like you are talking about and we never had any problems. When I renovated the basement I did replace everything with pex and drilled holes through the joists to get the lines up off the ceiling. The hot water lines don't get hot enough to cause any hazards and it's ok to for the copper to touch any non-metallic objects.
dannyoung85 is offline   Reply With Quote
Old 12-28-2013, 11:29 AM   #4
It's the condensation on the cold pipes in contact with the paper backing, and the sound of water running through the pipes in direct contact with the rock acting like an amplifier that may cause issues.
Because someone else did it does not make it right.
Old 12-28-2013, 11:44 AM   #5
Rewards Points: 225
I dont have a picture.
Old 12-28-2013, 01:33 PM   #6
An old Tradesmen
Rewards Points: 9,502
A copper water pipe for hot water should never touch/rest on drywall, as it expands when it get hot and then contracts as it cools. It will wear a way the dry wall.
Old 12-28-2013, 06:21 PM   #7
Rewards Points: 1,950
Just fur it out with some 1.5 inch wood.
Ghostmaker is online now   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Replacing Galvanized Pipes with Copper Bantymom Plumbing 0 02-28-2010 10:13 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
Copper pipes - do i have a problem? Pics! redpen Plumbing 2 12-29-2009 04:40 PM
Replacing galvanized with copper pipes. Twinvtec Plumbing 18 02-24-2009 08:53 PM
