Copper Pipe Support - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2016, 03:16 AM   #1
yyz
Rewards Points: 50
Copper pipe support
Hi there,
I've got a copper pipe loop assembly that comes out about 2 inches from the drywall, jogs up 90 degrees about 6 inches, across about 10 inches and then 90 degrees down 6 inches and back into the drywall. Is there a support mechanism that can be added to make sure that if anyone or something falls into the loop, something can protect the loop?
Thanks, Chris
yyz is offline   Reply With Quote
Old 08-13-2016, 06:46 AM   #2
Rewards Points: 18,776
Re: Copper pipe support
Got a picture so we can see what your seeing?
What's the loop for?
Old 08-13-2016, 07:12 AM   #3
hkstroud's Avatar
Rewards Points: 6,684
Build your self a shelf. Get a piece of 1x4 or 1x6 about three foot long.
Cut a couple of legs about 6" long. Cut legs into an Oge shape and attach.
Attach shelf to wall above pipe with a couple brass "L" brackets and and screws in narrow part of legs.
hkstroud is online now   Reply With Quote
Old 08-19-2016, 10:30 PM   #4
yyz
Rewards Points: 50
Sorry for the delay. Here is a picture. It comes out of the wall, goes up, across, down and back into the wall. The space between the wall and the pipe at the top is about 2 inches. I would like to put something between the wall and the pipe to give it support from being pushed inward. Hope it makes sense...
Last edited by yyz; 08-19-2016 at 10:32 PM. Reason: Sorry, I'm not sure why the image is upside down...
Old 08-19-2016, 11:03 PM   #5
hkstroud's Avatar
One on each side of the PRV
The Following User Says Thank You to hkstroud For This Useful Post:
yyz (08-19-2016)
Old 08-19-2016, 11:46 PM   #6
yyz
Rewards Points: 50
Awesome. Exactly what I was looking for ...
Cast iron pipe support strapping and sway bracing Deck Plumbing 4 05-26-2016 07:03 PM
Copper pipe grounding adgjqetuo Electrical 9 04-05-2016 08:42 AM
Bad solder joints, fixable? ponch37300 Plumbing 10 11-18-2015 04:36 AM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 08:44 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
