Converting Electric Stove To Gas Stove - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2016, 12:24 PM   #1
Rewards Points: 2
Converting electric stove to gas stove
hello,
I have about 20 feet of 3/4 inch pipe supplying 1/2 pipe to furnace and 1/2 inch pipe to hot water heater.
The house used to have a 1/2 inch pipe supplying dryer and 3/4 inch pipe ran to what I think was a gas stove. both of those line have been plugged up.
I would like to tap into the existing pipes and convert electric stove to gas.
Should I tap into 3/4 inch main supply or can I use the old 1/2 inch supply line that used to supply the dryer?
Also, can I assume that because there used to be other appliances using gas that the supply is enough?
jmazz888 is offline   Reply With Quote
Old 11-26-2016, 02:03 PM   #2
Rewards Points: 80
Re: Converting electric stove to gas stove
How long is the longest used run?
BTU input for each appliance?
Please describe the pipe system a bit better. As in what is tied in where, and what is common. The 3/4 is probably the better choice.1/2 is a bit small unless you're stove is fairly small and/or close to the main line.
Cheers!
supers05 is offline   Reply With Quote
Electric stove problem jaywalleye Electrical 5 10-01-2013 07:11 AM
Overload? Running electric stove and stackable W/D on same breaker Jody-KY Electrical 4 04-09-2011 02:32 PM
changing old 1800 model stove from electric to gas Rangerwife731 Appliances 2 09-23-2009 07:58 PM
re-wiring an old electric stove user62257 Electrical 3 09-15-2009 11:44 AM
Electric Stove Help tempmeo Electrical 7 06-05-2006 07:18 PM
