Convert Compression Thread To NPT - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2016, 06:40 PM   #1
Rewards Points: 36
Convert Compression Thread to NPT
Sort of a plumbing question....although it's for an air compressor.
I am replacing my air compressor pump and will need to re-plumb. The tank check valve has a 1/2" (tube) compression fitting. I want to convert this to 1/2" NPT (female NPT ideal but I can make male work too).
Is there an adapter that will convert male compression threads (at the bottom of the image below) to NPT threads?
Convert Compression Thread to NPT-cb18124c-e0e0-475c-ae56-1ca7483b042b_1000.jpg
Dusky is offline   Reply With Quote
Old 11-16-2016, 08:25 PM   #2
Rewards Points: 18,794
Re: Convert Compression Thread to NPT
Any Home center should have one that looks like this.
If all they have is male then just add a coupling.
http://www.homebrewing.org/12-FPT-x-...eYehoCZ5fw_wcB
Old 11-16-2016, 08:36 PM   #3
Rewards Points: 5,614
Maybe this would work for you. Your check valve /w compression then copper to a compression/pipe adapter, then pipe to where ever you need it.
Old 11-16-2016, 08:38 PM   #4
Rewards Points: 36
I need sort of the reverse of that adapter. Where the female pipe threads are in that adapter, I need those to mate with compression threads and have the "top" be pipe threads (NPT) so I can plumb to the pump using standard pipe.
Old 11-16-2016, 08:39 PM   #5
Rewards Points: 36
I think that would do it! Where can I buy those?
Old 11-16-2016, 08:40 PM   #6
Rewards Points: 1,036
You really need to plumb the compressor pump to the check valve with tubing and not solid with threaded pipe. This is often done using copper tubing for better heat transfer to help cool the compressed air but more importantly to offer some vibration dampening. The tubing is normally routed so it has a loop or a few oversized bends to allow some movement. Plumbed solid with threaded pipe the vibrations will likely crack the pipe at the threads or worse yet the compressor itself. You can easily find the correct compression fitting to either male or female pipe thread to screw into the compressor pump, then you will be able to connect the compression fitting in the pump to the compression fitting on the tank check valve with tubing.
iamrfixit is offline   Reply With Quote
Old 11-16-2016, 08:46 PM   #7
Rewards Points: 36
I'll be using something similar to this so it's not rigid although it is NPT pipe thread
https://www.grainger.com/product/HOS...tal-Hose-2ZV57
Old 11-16-2016, 09:19 PM   #8
Rewards Points: 36
Thanks, Joe. I was thinking a straight adapter without using any tubing...but it looks like that might not be available. Your suggestion should work.
Intermittant total compression loss? johnd393 Automotive Repairs 7 07-26-2014 11:08 AM
Metric compression fittings ??? rutalkn Plumbing 3 11-27-2007 10:43 PM
