Constant Gurgling Sound In Wall - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By lenaitch
Old 12-20-2016, 02:12 PM   #1
Rewards Points: 2
Constant Gurgling Sound in Wall
There has been a constant non-stop gurgling sound in the walls of my house for the last 3 days- I can hear it from my bedroom and from the bathroom and it is coming from outside wall adjacent to the backyard. About 4 days ago I dropped a razor head in the bathtub drain, Iím not sure if that is the cause of this or not (tried to get it out with a magnet tied to a string, didn't work... drain isn't backing up though). Does anyone have any idea what this could be and if so, is there a home remedy I could do? I'll call a plumber if I have to, but I am really hoping to save my money.
linzie93 is offline   Reply With Quote
Old 12-20-2016, 02:48 PM   #2
Rewards Points: 76
Re: Constant Gurgling Sound in Wall
I would say it "sounds" like you have a vent stack that is clogged and not allowing the air out of the system. This makes the water bubble and air "gurgles" up the pipe.
URY914 is offline   Reply With Quote
Old 12-20-2016, 03:00 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,102
I agree it does sound like a blocked vent but it would only "constant, non-stop" if water was running all the time. Any chance it could be coming from a partially-blocked downspout?
The errant razor head (assuming a disposable-type razor) probably won't cause much of a blockage and might still be in the trap, but it will over time catch hair and other material which could cause a problem down the road.
lenaitch is offline   Reply With Quote
Old 12-20-2016, 03:09 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,572
Snow on the roof?
Old 12-20-2016, 03:18 PM   #5
Rewards Points: 1,054
If you're worried about the tub/shower trap, you can use a plunger to suck loose stuff out. You can also pull the tub vent cover/stopper off/out and snake the trap. Warning, most tub traps are loaded with hair and slimy/stinky black goo.
To test vent function, fill up the tub and drain it. A properly working vent will let the tub drain fast, if the trap is clear. Are you sure the sound is not coming form your toilet?
clarenceboddick is offline   Reply With Quote
Old 12-20-2016, 03:35 PM   #6
RRH
Rewards Points: 1,486
You need a plumber for this and hope he can get it out. It is a partial blockage.
You could try your luck. Cover the tub overflow with duct tape or a wet rag. Then try a wet Dry vac in the tub drain
RRH is online now   Reply With Quote
Old 12-20-2016, 03:40 PM   #7
Usually Confused
lenaitch's Avatar
Originally Posted by Windows on Wash View Post
Snow on the roof?
Actually just a slight salt and pepper. No bad for 65.
Windows on Wash likes this.
Old 12-20-2016, 04:38 PM   #8
Is there something else close to where you're hearing the sound, like a water heater? House main supply pipe/valve. For the sound to be happening all the time, that would have to be something that is plugged into electricity or connected to the water supply. Drain pipe issues would only happen when they are being used. You could try shutting the main breaker off and see if the sound goes away.
Old 12-20-2016, 07:06 PM   #9
ZTMAN's Avatar
Rewards Points: 628
ZTMAN is offline   Reply With Quote
Old 12-21-2016, 07:29 PM   #10
Rewards Points: 288
Do you have a recirculation line on your hot water? If you do, maybe something has gone wrong with the pump controls and it's pumping constantly
BlackTiger is offline   Reply With Quote
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Slight crackling/popping sound in wall switch JayBird Electrical 3 08-06-2010 10:37 PM
Constant sound flowing water at meter tbeaulieu Plumbing 5 03-06-2010 08:44 AM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
