Connecting Two Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By paul100
  • 1 Post By lisaabrams
  • 1 Post By rjniles
  • 1 Post By hkstroud
Old 10-01-2016, 05:37 PM   #1
Rewards Points: 64
Connecting two supply lines
My sink cold supply line is about 6 inches too short. I'm trying to connect two supply lines because replacing with a longer one is too complicated. I went to my local hardware store and they recommended this setup. Two male straight fittings and a connector between.
I've tightened each as much as I can (using two wrenches) but there is still some room left. Is this how it's supposed to be? Or should it thread all the way?
Is this the best way to connect the lines?
I've got it hooked back up and there is a tiny leak still. Frustrating!
lisaabrams is offline   Reply With Quote
Old 10-01-2016, 05:41 PM   #2
Rewards Points: 64
Re: Connecting two supply lines
Here's another photo.
Old 10-01-2016, 06:05 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 818
Wrong for fitting. You need a flare union.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 10-01-2016, 06:14 PM   #4
hkstroud's Avatar
Rewards Points: 6,684
Take apart and re-warp with Teflon tape. You need to wrap at least four wraps of tape. More won't hurt. Pipe dope would work better.
You said you used wrenches. Look like you used pliers. Wrenches will work much better.
hkstroud is offline   Reply With Quote
Old 10-01-2016, 09:26 PM   #5
Rewards Points: 2
They make a line that already has the proper ends on it. so you wont need any fittings to extend it
joecaption likes this.
paul100 is offline   Reply With Quote
Old 10-02-2016, 10:10 AM   #6
Rewards Points: 18,822
What's the lines you have now made of?
What your showing is a compression fitting, there the only place that would have been taped or doped is where they screw into the coupling, never on the compression nut.
Would have been far simpler to just use a longer flex supply line, less chances of leaks.
About a 5 min. job with a basin wrench.
Old 10-02-2016, 12:39 PM   #7
Rewards Points: 64
Thank you! I found a 3/8 compression union at the big box store. Installed it and no leaks!
rjniles likes this.
Old 10-02-2016, 12:48 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 818
Glad you figured out what I really meant. I said flare and meant compression.
lisaabrams likes this.
Old 10-02-2016, 12:48 PM   #9
Rewards Points: 64
Hi Joe,
The current supply line from the faucet is black. I assume they're the ones that came with the faucet installed ~10 years ago. I too thought the easiest thing would be to replace the entire line with a longer one, however, when I looked under the sink and up at the bottom of the faucet under the counter, both the hot, cold and faucet extension line (it pulls out) all connect in together in the base of the faucet itself. There's about 3 inches between the sink and inside cabinet wall -- way too small for me to maneuver.
I was able to find a 3/8 compression union and it did the trick!
Old 10-02-2016, 12:52 PM   #10
Rewards Points: 64
Used an adjustable wrench and locking pliers to hold the center. All set now!
Old 10-02-2016, 12:53 PM   #11
Rewards Points: 64
Hi Paul, I looked at the big box store and couldn't find these -- they would definitely be preferred!
Old 10-02-2016, 01:25 PM   #12
hkstroud's Avatar
For future reference this type of wrench is great to get up behind a sink.
The Following User Says Thank You to hkstroud For This Useful Post:
lisaabrams (10-02-2016)
strange behavior with kitchen faucet supply lines NABRIL Plumbing 8 01-13-2014 10:04 PM
strange behavior with kitchen faucet supply lines that flake NABRIL Plumbing 2 01-12-2014 09:19 PM
replacing/altering cast iron supply & return lines? jeffro83 HVAC 5 05-12-2011 06:14 PM
Tapping CPVC supply lines for new bathroom - question NEW-B Plumbing 0 05-12-2011 09:20 AM
Right size supply lines to bathrooms Mudball Plumbing 7 12-29-2009 08:26 PM
