Connecting Old To New In-ground Irrigation Tubing - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2015, 09:49 AM   #1
Rewards Points: 147
connecting old to new in-ground irrigation tubing
so the house I bought has a sprinkler system. needs some work. holes in the lines (animals?) and such.
I am splicing some 1/2 inch hose I got from Lowes (Orbit brand) together to the exiting tube line all is going well except no matter how tight I screw the barbs/couplings into the two ends of the hose....they still leak.
so it appears the issue is in connecting older/existing softer 1/2 inch hose to newer, thicker 1/2 inch hose. they are both 1/2 inch but the newer stuff is slightly thicker inside so you really have to twist the simple style barb/connector in and as a result, it gets a nice seal but on the other side, the barb goes in much easier.....and leaks. Lowes also sells a heavier duty coupling with a locking collar. that seems to get a good seal on the older, softer hose. but the newer thicker hose....I can't get it to fit on.
any idea how to make that connection tighter? Teflon tape? some kind of putty or glue? would the heavier duty connectors (where you put the barb into the tube and they also have a ring collars) make a difference?? photos attached. thanks
connecting old to new in-ground irrigation tubing-p1070089.jpg   connecting old to new in-ground irrigation tubing-p1070091.jpg
tarheelblue is offline   Reply With Quote
Old 05-31-2015, 12:23 PM   #2
Rewards Points: 1,930
Dig up enough of the old so you can read the numbers and get the same stuff.
Ghostmaker is online now   Reply With Quote
Old 05-31-2015, 12:49 PM   #3
Rewards Points: 278
Those look like drip irrigation fittings.
You'll need a crimping tool for the clamps. I think it's around $15. It's not the same as PEX.
Put the clamps over the pipe. I usually use 2 per side. Heat the end of the pipe for about 5 seconds with a propane torch. I usually point the flame down the open end of the tubing. Put your coupling in. Then slide the clamps over the coupling and crimp. Repeat with the other side.
I'm using HD links as my local Lowes doesn't carry this stuff.
http://www.homedepot.com/p/Apollo-1-...10PK/202817141
http://www.homedepot.com/p/Unbranded...5?N=5yc1vZbuuc
Dan
djlandkpl is offline   Reply With Quote
connecting ground bars between two houses ausqb Electrical 21 04-21-2013 06:43 PM
connecting ground wire to green gound screw sco Electrical 0 09-22-2010 05:43 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Connecting two ground buses. tgidave Electrical 2 06-30-2010 08:22 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
