Connecting 1" Pex Pipe To 1" Poly Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2015, 10:57 PM   #1
Rewards Points: 28
Connecting 1" Pex Pipe to 1" poly pipe
OK I give up, I have 1" main water line from well coming through foundation. I want to install 1" Pex pipe to it. From my readings The 1" poly pipe is 1.049 inside dia and 1.189 o/s dia. The 1" pex Inside is 0.862 and o/s 1.125. Any fitting or fittings that will mate both?
mcclure440 is offline   Reply With Quote
Old 06-12-2015, 12:55 AM   #2
Rewards Points: 6,566
Welcome to the plumbing industry that's had us screwed for over a hundred years and continue the trend.
You may have to resort to having a brass barbed fitting made. Sad isn't it.
Old 06-12-2015, 01:08 AM   #3
Rewards Points: 750
that or just continue with the poly pipe.
Hick is offline   Reply With Quote
Old 06-12-2015, 05:50 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,312
Ayuh,.... As far as I know, you'll need a hose barb to threaded fittin', to a threaded to pex fittin',.....
Bondo is online now   Reply With Quote
The Following 2 Users Say Thank You to Bondo For This Useful Post:
rjniles (06-12-2015), tylernt (06-12-2015)
Old 06-12-2015, 07:51 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 290
Go to a good wholesaler. if they'll sell to you, they will stock a pex x barbed brass adapter. They're pretty common here
Purchase it and a couple hose clamps. Apply a little heat to the poly to soften it slightly. Then insert the adapter in the poly and tighten it down with the clamps.
Old 06-12-2015, 11:08 AM   #6
Special User
Rewards Points: 1,230
I just did this. I used a poly-thread fitting and a thread-pex fitting. I also stuck a ball valve in between for good measure, not because it was necessary, but just because I wanted one.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 06-12-2015, 02:17 PM   #7
Rewards Points: 1,910
Whats the best way for him to apply the heat to the poly?
Old 06-12-2015, 02:21 PM   #8
Special User
I know a lot of guys use a torach but unless you're experienced, that's sketchy as you can overheat the pipe leading to deformation and leaks. Dipping in a cup of hot water or application of a blow driver (or heat gun on LOW) are a bit safer.
The Following User Says Thank You to tylernt For This Useful Post:
jogr (06-14-2015)
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Joining 1/4" walled poly pipe IDEAS NEEDED!! CallMeChaz Plumbing 0 05-22-2012 09:04 AM
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 03:33 PM
Repairing black poly pipe MelAuston Plumbing 4 10-31-2007 08:54 PM
