Connect Cast Iron To New PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2016, 12:33 PM   #1
Rewards Points: 66
Connect Cast Iron to New PVC
Hey Folks,
I'm doing a bathroom total gut and remodel and found that for a period of time there was a leak at the wax seal and 4" cast flange and pipe cast in concrete below is beyond use or repair. As bathroom is demoed, access to where it joins at a wye in crawl space is easy.
My initial plan was to demo out all the concrete and cast iron back to the wye at the hub. (see attached photo circled in red) I was considering removing the 4" cast, and use a donut reducer to 3" and bring the 3" back to new PVC flange and re-pour concrete.
I keep reading a lot about hub, versus no-hub connections, and really can't decide if it's better to remove pipe from hub, use donut reducer, or alternatively use a chain cutter to break the 4" cast lead in pipe to the hub, and use a no-hub, then transition to the 3" further up?
The donuts seem to be generically called "furnco" fittings, from what I can gather. (see attached photo) As the entire wye in crawlspace sits on grade in crawls space, I don't think support is a factor.
Anyway, hope to hear the pro's and con's to each option, as I'll go with the better alternative as when bathroom is closed back up crawl space access would not be as easy.
Thanks all !!
keithhe is offline   Reply With Quote
Old 01-10-2016, 12:58 PM   #2
Rewards Points: 1,866
Break the pipe before the hub with a sludge hammer. Then carefully remove the oakum and lead joint. Grease the new rubber seal with crisco and make your adaptation. From your pictures it looks like you have extra heavy cast iron and trying to adapt to it with a transition band may become problematic.
Make sure you wear goggles to cover your eyes.
Old 01-10-2016, 01:09 PM   #3
Rewards Points: 66
Thanks Ghostmaker. So, you are in favor of the "donut" method. That was my first instinct too, then started reading and got caught up in the no-hub versus donut connection. I'm not convinced these were leaded in, as the connection, nearest camera, appears to be some type of roofing tar. Main connection at hub does not have that though. All the cast seen in photos is in good shape, it's what is rising in concrete in picture to flange that is bad shape.
Old 01-10-2016, 08:22 PM   #4
Just make sure your rubber donut is to adapt to scd 40 plastic from cast iron.
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 02:17 PM
Making new plumbing connect to old Cast Iron plumbing fallvitals Plumbing 12 10-13-2012 05:52 PM
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 03:42 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
