Condensate Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2016, 10:44 PM   #1
Rewards Points: 4
Condensate pipe
I just had a home inspection done and the inspector noted the following for the a condensate drain over the washing machine nozzle. What would be the best solution for this? What are the costs? and does it seem to be leaking? I read online that it shouldn't leak, but the nozzle looks fairly corroded like it has.
xamber is offline   Reply With Quote
Old 03-01-2016, 10:58 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 182
It appears to be PVC pipe. There are at least 2 fixes-
Use 2- 45 degree fittings and offset the pipe along the side of your washer hose and align it to the stand pipe.
Or use 2- 90 degree elbows.
Another option is to find another receptor to drain it to, but that probably isn't feasible at this stage.
The line will drip if it is a condensate line from heating/cooling equipment in your attic.
If it is a pan drain then you need to determine why a normally dry pan has water in it.
Actually, since this is a new house to you, I suggest you get familiar with what that pipe is hooked to
BTW- welcome to our forum!
Old 03-01-2016, 11:13 PM   #3
Rewards Points: 4
Thank you so much for the quick reply and the solutions. The contract is pretty much a done deal, so I guess I'll have to figure out what's causing the drip when I move in
Old 03-01-2016, 11:32 PM   #4
Plumber
Rewards Points: 182
Keep us posted and feel free to ask questions or contribute
Condensate pipe droopdog7 HVAC 3 05-28-2014 05:50 AM
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Whatís the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
