Condensate Drain To Washer Stand Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2016, 12:40 PM   #1
Rewards Points: 59
Condensate drain to washer stand pipe?
I would like to connect a condensate line from a new tankless water heater and gas furnace to a washer stand pipe. Is this okay?
I was planning on adding a wye to the vertical standpipe just above the trap, and then use a threaded bushing to convert to the PVC condensate line. Does it matter if I install the wye as close to the trap as possible? I would like to get as much slope on the condensate line as possible.
Do I need to increase the size from 3/4 to 1" since I will have the tankless water heater condensate, furnace condensate, and maybe a humidifier all connected?
Thanks!
handyman923 is offline   Reply With Quote
Old 10-09-2016, 04:35 PM   #2
Rewards Points: 1,082
Re: Condensate drain to washer stand pipe?
Had mine similar idea for a long time. But because condensate runoff from furnace and heater are somewhat acidic, better to add wye further down so washer (used on a regular basis) can flush the line and keep it PH balanced.
If yours will get that flush, probably ok.
diyorpay is offline   Reply With Quote
Old 10-09-2016, 06:04 PM   #3
Rewards Points: 454
Depending on how acidic they are you would want to run them through a neutralizer otherwise you are running acid through your drain system. In many areas these are required by code, I don't know the code for your area so you would have to research that yourself.
KC_Jones is offline   Reply With Quote
Old 10-09-2016, 06:07 PM   #4
Rewards Points: 38
Neither idea is legal or recommended. If you pump condensate up to the top of washer drain pipe, you can run the condensate in to the pipe by using an air gap mounting. If you have PVC drain pipe, no worries on PH of condensate. NO WYE, you really don't want to do that.
SHR Plumber is offline   Reply With Quote
The Following User Says Thank You to SHR Plumber For This Useful Post:
TheEplumber (10-10-2016)
Condensate Drain Line & Pan Problems hobbzilla HVAC 10 08-04-2014 11:31 AM
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
Washer drain overflow aviashn Plumbing 3 07-08-2012 09:16 PM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
