Concrete Slab Penetration - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2015, 06:02 AM   #1
Rewards Points: 51
Concrete slab penetration
I'm getting ready to pour a slab for a garage. Is regular pex tubing suitable to be used for penetraton through the slab?
deepstuff is offline   Reply With Quote
Old 11-23-2015, 06:07 AM   #2
Rewards Points: 18,998
It is, but it should be sleeved.
Old 11-23-2015, 06:20 AM   #3
Rewards Points: 51
With what? Suitably sized plastic tubing? Steel pipe?
Old 11-23-2015, 06:31 AM   #4
PVC pipe will work.
Are you trying to pore this slab yourself? Ever done one before?
Old 11-23-2015, 06:35 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 290
Slightly oversized PVC conduit sweeps slipped over the pex works well
Old 11-23-2015, 06:40 AM   #6
Rewards Points: 51
Av somone pouring and finishing slabs. I'm just setting up what I can.
Old 11-23-2015, 07:00 PM   #7
Rewards Points: 1,952
Use armaflex tubing insulation where it penetrates. In the ground it should be completely bedded in sand or P-gravel. If you have neither use the armaflex the entire length until your out of the ground. Hot water line pex will expand up to 4 inches from cold to the tank temperature. And rocks with sharp edges may eventually wear through.
http://www.homedepot.com/b/Plumbing-...5yc1vZbuy9Zaee
Concrete Slab repair for plumbing trench dshap1984 Concrete, Stone & Masonry 28 03-03-2015 08:17 PM
Pouring a concrete slab ponch37300 Concrete, Stone & Masonry 11 02-18-2015 05:33 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
