Concealed Rough In For Toilet - Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2017, 08:40 PM   #1
Rewards Points: 170
Concealed rough in for toilet - help!
I bought a tract house that was built in 1982. They were part of a low-income project and all had to comply with certain specs. They had to be three bedroom, one bath, single car attached garage and about 1000 to 1100 sq. ft. Many of these had a half bath that was roughed in but was finished as a closet.
So, I bought one of these that was a fixer upper and am working on the half bath/closet to convert it to the half bath. I removed some of the drywall and found the rough in supply lines. In the floor, which is a slab there was what appeared to be a red plastic coffee can lid. I chiseled the concrete away from it expecting to find a toilet flange. Instead there is a cast iron pipe about 2 ID and 3 OD. It has about 1 of clearance around it.
I am guessing that a toilet flange was made that went over the outside and oakum was driven in and lead poured over it.
I have never seen anything like this and am stumped. I would like a toilet flange that I can set a toilet on. I am hoping someone is familiar with this, what do I do? Thanks.
comfun1 is offline   Reply With Quote
Old 12-16-2017, 10:27 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,924
Re: Concealed rough in for toilet - help!
Here is Richard from this old house demonstrating what you need.
Old 12-17-2017, 07:15 AM   #3
Rewards Points: 170
I just finished the video. After Richard removed the old flange the pipe sticking up looks just like the situation that I am faced with except I think his pipe may be larger than mine. I think the fitting with the red flange that goes over the outside would work for me. I'm afraid anything on the inside of mine would restrict or clog the passage of solids.
Now I just need to locate a source for one of those flanges. Thanks for the help Joed.
Old 12-17-2017, 08:00 AM   #4
Rewards Points: 40
Are you looking for this?
https://www.homedepot.com/p/Sioux-Ch...6-GP/202313119
This is the other one in the video
https://www.homedepot.com/p/Oatey-4-...-100139480-_-N
R2D2 is offline   Reply With Quote
Old 12-17-2017, 08:59 AM   #5
Super Moderator
joed's Avatar
The inside flanges are designed for toilets. The hole is made large enough for the stuff.
Old 12-17-2017, 09:43 AM   #6
Peace be with you
DR P's Avatar
Rewards Points: 1,860
These flange pics r 4"
the piping measured is 3" nominal
A 3" Inside CF is not code - too restrictive
doesn't mean it isn't made just not legal to install
if big box doesn't carry -
go to a real plumbing supply and buy the correct (red) flange
and bolt down CF with tapcon screws...
Sad to see Richard didn't perform that code requirement
Peace
DR P is offline   Reply With Quote
Old 12-17-2017, 11:24 AM   #7
Rewards Points: 8,647
They did not show him adding the screws, flange to floor, but they are visible near the end of the video.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 12-17-2017, 07:58 PM   #8
Rewards Points: 170
My inside diameter is about 2 3/4 ". I don't think anything going inside is going to work, but I seem to have plenty of room outside. I think the contraption they put over the cast iron pipe prior to pouring the concrete is designed for either a cast iron flange or something over the outside. I live in a town of 10,000 so our fitting supplies are limited. I contacted a plumber and from my description over the phone he said it probably wouldn't take him more than an hour to fix it. He said he can get to it tomorrow or Tuesday. I think that some of the pieces you guys have showed me would halve solved my problem but our local stores don't have them and apparently have not heard of them. My wife says it will be money well spent as I will learn something. Great to have a forum like this.
Rough in valve function question spacepunch Plumbing 11 01-04-2017 09:50 PM
NickWa's Basement Renovation NickWa Project Showcase 50 07-01-2015 02:16 PM
Basement Bathroom Rough In LarryM Plumbing 5 12-05-2014 03:45 PM
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
