Compression Stop On PEC? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2016, 10:52 AM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
Compression stop on PEC?
I am installing a new vanity and I wanted to replace the multi turn stops with quarter turn stops. Since the pipe out of the wall is PEX, i planned on cutting off the old stop (I have length to play with) and installing a Sharkbite stop. As it happens the supply house was out of the Sharkbites and I did not want to drive 20 miles to Home D. The counter man suggested I use a regular compression stop with a plastic ferrule and PEX tube insert.
I bought the stops but am having second thoughts. Is the compression stop a valid connection to PEX? I have the project on hold. Thanks for any insight.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 02-13-2016, 11:06 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
I wouldnt trust it, especially on the hot side where the pex will get soft, the shark bit grips with little teeth and does not use the compressive nature to hold it on, I have had many failures in the past with plastic water supplies slipping out of a compression fitting both hot and cold...if it lets go when your away or at night..it could be a disaster..even with the stiffener in the pipe, and that should be brass or stainless..not plastic..the ferrel should be plastic..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
ben's plumbing (02-13-2016)
Old 02-13-2016, 06:48 PM   #3
Rewards Points: 582
agree with whatsrns....don't trust it...its not worth it..drive the 20 miles...:
The Following User Says Thank You to ben's plumbing For This Useful Post:
joecaption (02-13-2016)
Old 02-13-2016, 06:59 PM   #4
Rewards Points: 6,652
RJNiles, if you order the parts off of Amazon you can get it by Tuesday. Supply house would be $5.99 S&H ground. Twice as much for the cost of the part, to get it next or 2nd day.
Old 02-13-2016, 07:05 PM   #5
Rewards Points: 18,808
I agree just not worth the risk.
Old 02-13-2016, 07:16 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 188
Some plumbers here use these all the time. I haven't heard of any problems
The Following User Says Thank You to TheEplumber For This Useful Post:
gregzoll (02-13-2016)
Old 02-13-2016, 07:57 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
Well it seems we have a disagreement . 2 say no, 2 say OK ( I am counting the supply house counter man). I am twixt and tween.
Old 02-13-2016, 08:05 PM   #8
on pex or on copper pipe? on copper pipe, no problem they will hold...
Old 02-13-2016, 08:06 PM   #9
its only 1 for..unless your counting yourself as 2..LOL
Old 02-13-2016, 08:15 PM   #10
Plumber
Rewards Points: 188
On pex of course. Think pac joint. Stiffener goes in the poly pipe, then a compression ring and fitting on the outside.
Pex is softer than the ferul so it will dig in- same as brass ferul on copper.
Granted, I only see a couple guys use them regularly.
Old 02-14-2016, 02:02 AM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
A question for those who think the stop will blow off the PEX. How is this any different than using a 3/8 PEX riser pipe to connect from the stop to the faucet? That is also a compression fitting with a plastic ferrule.
Old 02-14-2016, 07:18 AM   #12
I have had the hot side blow out on pex water supplies like the one you posted..all I use now are real chrome or copper and braided supplies...and no plastic nuts up by the faucet..the plastic seems to loosen with the constant hot cold cycles...for the few bucks for non pex connectors, it will cost less than a return call or insurance claim for water damage..
JERRYMAC (02-14-2016)
Old 02-14-2016, 02:07 PM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
Tried a little test. Connected a compression valve to a piece of PEX using a plastic ferrule. Did not use a tube insert as I didn't have an extra one. Hung it up with a full 20 pound propane tank hanging off the valve. It has been hanging there about 3 hours when I took this photo. I am going to leave it over night and see what happens.
Old 02-14-2016, 02:21 PM   #14
get out a hair dryer and heat the pex up, like hot water would be running through it and see what happens..
Old 02-14-2016, 02:24 PM   #15
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
I am going to let it hang overnight and I will try the hair dryer in the morning and report back.
Lovely senior lady needs help with a stuck compression nut barb1948 Plumbing 12 12-15-2014 04:06 PM
Need to buy good value compression tester for a DIY'er- Suggestions? amodoko Automotive Repairs 4 02-11-2013 10:22 AM
Condenser's fan & compressor run stop run stop run stop, Please Help! tuanngnt HVAC 8 04-01-2012 11:07 AM
Compression Valve for leaky pipe (not copper)? DIYsoon2Bpro Plumbing 11 01-18-2012 06:40 PM
Shower drain wont stop (pictures) homeowner432423 Plumbing 12 01-15-2012 09:49 PM
