Compression Fitting Won't Fit On Evaporative Cooler Supply Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2015, 11:49 PM   #1
Rewards Points: 4
Compression fitting won't fit on evaporative cooler supply line
There's a section of my supply line to my swamp cooler (1/4" copper) on the roof that had a small crack in it. So, I figured I'd just cut out that small piece and use a compression union fitting to connect it back together. I got the compression fitting from HD, in the section with all the swamp coolers and cut my line. However, the compression sleeve is too small to fit the copper tubing, and so is the threaded part of the fitting that the copper line is supposed to go into. It's not just a tight fit, either - there is no way it's going to go on.
Am I doing something stupid here, or is there something I'm not getting? I've used compression fittings before (on bigger pipe), so I know how they're supposed to work. I cut the tubing with a hacksaw and then cleaned up the ends, so I don't think I deformed the tubing significantly.
Thanks for any ideas.
jorgenman is offline   Reply With Quote
Old 06-02-2015, 12:47 AM   #2
Rewards Points: 6,378
Water remained in the tubing, froze and increased the diameter, hence the crack. Replace the tubing.
Old 06-02-2015, 08:01 AM   #3
Rewards Points: 777
Some refrigeration piping is different than plumbing piping/tubing.
ct18 is offline   Reply With Quote
Old 06-02-2015, 08:11 PM   #4
Rewards Points: 4
Yeah, it just turned out that a bigger section expanded than I realized. I just replaced that whole section, and everything's good! Thanks for the input.
The Following User Says Thank You to jorgenman For This Useful Post:
SeniorSitizen (06-02-2015)
Replacing main water supply line from damaged copper to pex. HitLines Plumbing 14 07-30-2013 06:09 PM
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
Leaking compression fitting on main water line harrison8772 Plumbing 5 04-26-2012 08:33 PM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 01:41 PM
