Cold Water Line To A Gas Hw Heater - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By TarheelTerp
Old 02-25-2018, 12:58 PM   #1
Rewards Points: 230
cold water line to a gas Hw heater
I just "uninstalled" a gas hot water heater from a friend's place.
the Cold water intake line was a bit troublesome to disconnect (it wouldn't just unscrew) and in the end the copper line above the heater snapped and so we could remove the whole unit.
but, what remained in the tank was just loose. a Loose hanging white plastic tube.
I am wondering now if I "broke" something off in my brutish removal tactics.
Or, does that cold water feed line just normally hang loose into the tank?
(but if so, what drives the hot water back up and through the system?)
Or is this supposed to be a closed system, where everything - cold water feed, HW tank, HW out - is supposed to be water tight? (In which case I have to go in an reconnect the cold some how.)
pjstock is offline   Reply With Quote
Old 02-25-2018, 01:32 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,702
Re: cold water line to a gas Hw heater
Originally Posted by pjstock View Post
...and in the end the copper line above the heater snapped
In the future use unions or flex connectors
called a 'dip tube'
it sends the fresh cold water to the bottom
as opposed to leaking on the floor? yeah
MTN REMODEL LLC and lenaitch like this.
Old 02-25-2018, 01:44 PM   #3
Oso954's Avatar
Rewards Points: 1,898
The dip tube is usually set into or attached to a fitting or a nipple. Sounds like yours has popped or snapped off.
Replacement dip tubes are usually available from a supplier.
Oso954 is online now   Reply With Quote
Old 02-26-2018, 07:24 AM   #4
Rewards Points: 230
well now I know.
on closer inspection, at the top of the Dip Tube there is a fitting threaded on both sides, top and bottom.
I had just managed to unthread the bottom section, from the top of the tank itself.
just need to tape it and rethread it in.
Thanks for the help as always.
Mystery Valve On Hot Water Heater - NOT TPR raggedballs Plumbing 7 03-25-2016 09:03 PM
Hot water from cold pipes, plumbers are stumped seabeast Plumbing 75 03-31-2015 09:52 PM
Strange plumbing to my elec water heater > photos Flt_Simulation Plumbing 17 05-13-2014 04:52 PM
Vacuum breaker with tankless water heater? braman Plumbing 3 04-07-2013 01:40 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
