'Cold' Sometimes Runs Hot - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2015, 04:54 AM   #1
Rewards Points: 381
'Cold' sometimes runs hot
Why would the 'cold' handle on my bathroom faucet sometimes let out HOT water? The hookups are correct so I'm thinking it's something in the faucet.
Faucet's less than a year old so can't imagine it'd be faulty already but [shrugs shoulders]
Zamboknee is offline   Reply With Quote
Old 09-16-2015, 05:53 AM   #2
Retired Moderator
Rewards Points: 7,174
That double handle faucet is not likely causing HOT/COLD cross over---
Next time it happens,feel the feed pipe near the shut off valve---if the pipe is warm--
You are getting cross over from a near by single handle fixture--likely the shower mixer.
Ghostmaker (09-16-2015)
Old 01-01-2016, 09:09 PM   #3
Rewards Points: 381
If that's the case, how do I resolve it?
Old 01-01-2016, 10:18 PM   #4
Rewards Points: 1,938
Replace the cartridge of the single handle. Is it Moen by chance?
Old 01-01-2016, 11:44 PM   #5
Rewards Points: 381
No, Delta. And that cartridge is only about a month old.
Old 01-02-2016, 01:09 PM   #6
Try turning off your washer machine connection and see if problem remains.
Old 01-02-2016, 04:05 PM   #7
Rewards Points: 114
What single handle fixtures do you have in the house? Do you have any mixing valves or a recirculating pump? Does it do it every time or only certain times, if only certain times when does it happen? Does it run continuously hot or is it a momentary thing? Has it always happened or did it just randomly start? Did anything in the house change when it started, new washing machine, bath remodel, insta-hot, etc?
2x_Tom is offline   Reply With Quote
Old 02-24-2017, 04:39 PM   #8
Rewards Points: 381
Sorry, had some major life stuff so haven't been on top of this as much as I'd like.
Anyway...
The problem hasn't been very prevalent of late but it's rearing it's head again.
To your questions....
Kitchen sink, shower
No
Certain times but haven't documented (yet) when
momentary
Random
Nothing changed
blower runs for about a minute before the heat kicks in. fills rooms with cold air. bahmtf HVAC 8 02-14-2013 04:32 PM
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 03:21 PM
cold air intake carl sheffield HVAC 1 03-08-2010 04:42 PM
a/c blows and runs, no cold air cutiecavetoes HVAC 1 06-19-2009 05:49 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
