Cold And Hot Water Pipes Reversed - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 2 Post By Gregsoldtruck79
  • 1 Post By Nealtw
Old 07-15-2019, 03:19 AM   #1
Rewards Points: 26
Cold and hot water pipes reversed
It looks like the cold and hot water pipes on my shower faucet were reversed by our plumber when he installed it recently. He said that he cannot fix it anymore because he would need to break the tiles in my shower room to do so.
Anyway, my shower faucet is a Hansgrohe one and I'm wondering if I can somehow switch the valves inside it as a workaround. Here's its insides:
Any ideas?
kevindd992002 is offline   Reply With Quote
Old 07-15-2019, 06:19 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,340
Re: Cold and hot water pipes reversed
Not sure about Hansgrohe, but with most shower valves you can rotate the valve 180 degrees to swap the hot/cold mix. Turn the water off first. If that fails, what is behind this wall?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-15-2019, 06:30 AM   #3
retired framer
Rewards Points: 6,264
The water pipes have to be somewhere in the building behind drywall.
Do not use flat bottom gables with scissor trusses.
Old 07-15-2019, 07:11 AM   #4
Rewards Points: 26
Yeah, the water is already turned off. I guess I need to go deeper and unscrew that big nut. I'm not entirely sure what's behind the wall because I'm trying to go the faucet route first before anything.
Old 07-15-2019, 07:19 AM   #5
retired framer
Every other brand tells you how, I think you are out of luck.
Old 07-15-2019, 07:46 AM   #6
Rewards Points: 82
Any ideas?
Dang, you pros are getting soft hearted here on DIY. IF the plumber was licensed and was paid to do the project, then whatever happened to the building mantra advice, "Get the guy back and make him do the job right".
The OP should not have to correct someone's mistake, that he paid to get done. Even if the plumber has to break in to the shower water supply lines in the crawlspace or basement and cross them over to get the "cold on the right and hot on the left". JMO
Bud9051 and Nealtw like this.
Gregsoldtruck79 is offline   Reply With Quote
Old 07-15-2019, 09:36 AM   #7
Hammered Thumb
Rewards Points: 986
I'm with throwin down with the plumber. He should fix it, somewhere with access.
3onthetree is offline   Reply With Quote
Old 07-15-2019, 09:43 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 774
Sort of outside the box thinking, do you possibly have access anywhere other than behind the tile to the shower lines.... maybe you could just splice in and crossover your hot/cold feeds....and forget screwing with the valve.
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 07-16-2019, 01:06 AM   #9
Rewards Points: 26
Not getting softhearted in any way. That's the very obvious choice here but that isn't possible in our case. My parents cut corners with the contractor and I don't know the terms but he doesn't want to deal with them anymore. It's more headache dealing with them compared to just doing DIY repairs. This is just one of many problems.
And this is in the Philippines. It's very different with how things work in the US.
Good luck
Well, when the plumber was here I asked him about that and he said there's no way.
Oh btw, I don't think he's even a licensed plumber. He really sucks and we're the one suffering because of his half-baked jobs.
Sent from my SM-G950F using Tapatalk
Old 07-16-2019, 02:41 AM   #10
retired framer
And this is in the Philippines. It's very different with how things work in the US.Well, when the plumber was here I asked him about that and he said there's no way.
So it can be fixed if you can get in the back of that wall or or find where the pipes are coming from. crawl space ,attic , vanity.
Gregsoldtruck79 likes this.
