Cold Climate Vs. Plumbing In Outside Walls - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2015, 08:14 PM   #1
Rewards Points: 129
Cold climate vs. plumbing in outside walls
I am beginning to plan room layouts for a house in Northern Minnesota (-25 deg F. or colder in winter) and need some guidance on pipe runs in outside walls.
Must all water appliances against an outside wall be plumbed directly to the floor or ceiling without running in an outside wall?
Daneel is offline   Reply With Quote
Old 10-30-2015, 08:56 PM   #2
Rewards Points: 1,956
In a room like the laundry room or a bathroom, if you need pipes in an exterior wall you can build a double wall, the outside one full of insulation and the inside one open for pipes, each framed with 2x4's.
If it's a something-and-a-half storey building, watch for pipes in walls where the other side is in a cold attic. Watch also for pipes in the floor between a garage and a living space above.
ChuckF. is offline   Reply With Quote
The Following 2 Users Say Thank You to ChuckF. For This Useful Post:
Daneel (10-30-2015), SeniorSitizen (10-30-2015)
Old 10-30-2015, 10:28 PM   #3
Rewards Points: 6,404
Drywall is such a poor insulator, as long as the bare pipe is next to the drywall with the insulation on the opposite side, without exception, freezing isn't a problem as long as the structure is heated.
SeniorSitizen is offline   Reply With Quote
Old 10-30-2015, 10:56 PM   #4
Rewards Points: 1,938
You will need to double any walls you plan to run plumbing in to prevent freezing on an outside wall. I would strongly suggest that you use interior walls for all plumbing considering the extreme cold you have. So plan accordingly.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Daneel (10-31-2015)
Dry well in Cold Climate? Johngandersonjr Landscaping & Lawn Care 1 01-25-2015 05:20 PM
Travertine pavers driveway in cold climate Leopro Concrete, Stone & Masonry 7 01-04-2013 11:06 PM
How to finish concrete walls in cold storage room (basement) TomU Concrete, Stone & Masonry 6 11-11-2012 06:40 PM
Sunroom/greenhouse for cold climate sgbotsford Building & Construction 2 05-26-2011 07:59 AM
Protecting plumbing behind walls tripower Building & Construction 4 02-28-2009 11:12 AM
