Clogged Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2016, 11:09 AM   #1
Rewards Points: 2
clogged sink drain
I have a clogged bathroom sink. I have taken apart the trap and run a snake as far as I can, only about six inches, until it hits the intersection inside the wall. Put everything back together and still no flow. Is there something I'm missing?
ihateplumbing1 is offline   Reply With Quote
Old 03-27-2016, 12:13 PM   #2
Rewards Points: 5,642
Re: clogged sink drain
Pull the pop up drain plug mechanism and check for obstruction.
Old 03-27-2016, 12:21 PM   #3
JUSTA MEMBER
Rewards Points: 3,254
As senior sitizen says, check the pop-up plug assembly.
They often accumulate soaps and grease buildup.
ED
de-nagorg is online now   Reply With Quote
Old 03-27-2016, 04:45 PM   #4
Rewards Points: 18,796
Did you remove the piece coming out of the wall so you can help the snake make that 90 deg. turn inside the tee inside the wall?
Old 03-29-2016, 10:12 AM   #5
Rewards Points: 147
I've had better success with water pressure than snakes. There are rubber "balloons" that attach to garden hoses for different sized pipes.
Rango is offline   Reply With Quote
The Following User Says Thank You to Rango For This Useful Post:
srloren (03-29-2016)
Old 03-29-2016, 12:14 PM   #6
Rewards Points: 198
Most of the time obstructions in a Pop Up is hair. Remove the clip retaining the pop up lever that enters the tail piece of the lavatory. You can then remove the stopper/pop up and clean all of the hair from it and reassemble it. Fill the sink to just over the overflow opening and put some bleach in the water and allow the bleach to soak up the bacteria inside of the overflow of you lavatory sink. Do the bleach about once a month to keep the overflow from stinking.
srloren is offline   Reply With Quote
AC Drain clogged - goes into concrete - no drain outlet at outside evap unit = ???? ReEstate-Rookie HVAC 4 08-27-2012 08:51 AM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Island sink drain problem oldphoneman Plumbing 2 02-06-2012 10:56 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
