Clogged Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2016, 01:47 PM   #1
Rewards Points: 100
Clogged shower drain
Hello,
My shower clogged this morning and I have tried everything, draino, plunger, pipe snake and nothing works. The strange thing is that after I took off the drain cap, my pipe snake will only go down about 8" and then it feels like it hits something rock solid. I thought it was the bend in the drain pipe, but no matter which angle or how long I try to get past it, nothing works. I live in Pennsylvania, it's been really cold here, but I can't imagine the water in the pipe froze? Thanks for any advice!
williams_run is offline   Reply With Quote
Old 01-19-2016, 01:51 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
to be able to see whats going on, if you have a shop vac, vacuum out the water from the trap and look with a flashlight and see whats down there....and go from that point..8 inches is about right for the bottom of the trap, your snake might not be able to make the turn in the ubend of the trap...
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
JERRYMAC (01-20-2016)
Old 01-19-2016, 02:10 PM   #3
Rewards Points: 100
I cleared it out and found it is frozen. I don't have access from anywhere, should I try boiling water or wait for it to get warmer?
Old 01-19-2016, 02:17 PM   #4
ZTMAN's Avatar
Rewards Points: 604
Hot water. If the first shot doesn't fix it, suck the water out and repeat. Make sure after you clear the trap, that it didn't crack
ZTMAN is offline   Reply With Quote
Old 01-19-2016, 02:28 PM   #5
Rewards Points: 100
ok, thanks
Old 01-19-2016, 02:32 PM   #6
where is the trap in relation to an outside wall? that it would freeze
Old 01-19-2016, 05:49 PM   #7
Rewards Points: 1,852
IS your shower over a eve or a garage?
Toilet and Shower drain Bubble? Jefferoo Plumbing 3 09-03-2013 02:00 PM
Drain for preformed shower base svaic00 Plumbing 1 05-02-2013 10:11 PM
Shower to Tub; using the original drain? recmhb Plumbing 0 08-01-2011 10:07 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
