Clogged Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2015, 06:45 AM   #1
Rewards Points: 100
Takes about 30 seconds for it to appear in the sink. Eventually over a minute or so will drain slowly once water is turned off.
This is my wife's bathroom sink. It is on an interior wall. Mine is on an exterior wall where on the outside of the house is a 2 inch clean out.
Thoughts on how to address this? Trap is clean and not seeing backup anywhere else.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 09-23-2015, 06:59 AM   #2
Retired Moderator
Rewards Points: 7,174
Have you removed the pop up stopper yet? That is the place that catches hair most often.
Old 09-23-2015, 07:06 AM   #3
Rewards Points: 100
Yes, all that is and was clean. As I said, it takes about 30 seconds for the BU to start.
Old 09-23-2015, 08:35 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 248
I would start with a 1/4" cable down the trap arm. Of course you need to pull the trap to do that
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (09-26-2015)
Old 09-23-2015, 08:37 AM   #5
Rewards Points: 100
thanks
The Following User Says Thank You to digitalplumber For This Useful Post:
oh'mike (09-23-2015)
Old 09-26-2015, 02:20 PM   #6
Rewards Points: 100
OK so we are good here for now, but I think my Snake It device is ready for the garbage! What do you guys recommend I replace it with, for an HO? Don't mind spending a few bucks! I see lots of Rigid Drill type devices, any good?
or just a plain old snake? or something like this: Plumbers Flat Snake Drain Tool 3/4\" x 100\
Thanks!
Old 09-26-2015, 03:22 PM   #7
Retired Moderator
RIDGID 1/4 in. x 25 ft. Power Spin-41408 - The Home Depot
This type works on most lavatory drains---if this fails to do the job--rent a powered one.
Old 09-26-2015, 03:28 PM   #8
Rewards Points: 100
Thanks, what do you think of the Rigid K45? Line size?
Old 09-26-2015, 05:40 PM   #9
Retired Moderator
The listing mentions 3 different size cables---does the machine come with all three?
1/4 or 5/16 should clean out that line---
Old 09-26-2015, 05:42 PM   #10
Rewards Points: 100
I dont think so, will double check.
poor drainage from bathroom sink JKeefe Plumbing 5 08-13-2015 07:33 PM
Bathroom Sink Fills Up and THEN Drains Rapidly mark2741 Plumbing 2 09-02-2012 07:55 PM
Snaking a Bathroom Sink tigertown Plumbing 9 04-11-2012 09:39 PM
add second bathroom sink - tap into original denemante Plumbing 1 03-22-2011 12:21 AM
Bathroom sink is clogged. Karmapedler Plumbing 8 09-10-2010 09:00 PM
