Clog? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2014, 10:06 AM   #1
Rewards Points: 4
Question
Clog?
Bear with me as I have very little plumbing experience.
I noticed last night the smell of sewer gas coming from my basement drain and my sump pump was pumping out quite a bit of water, which is very strange for my house in the dead of winter.
After some investigation I realized my basement bathroom toilet doesn't flush. It just fills up with water, then slowly drains completely empty after waiting an hour or so.
Main floor bathrooms work fine, but every time I flush or use the shower on the main floor, that's when my sump pit starts to fill.
My uneducated guess is a clog in the main line, past the point of the basement bathroom, which causes the water from the upstairs bathroom to make its way into pipe that feeds the sump pit.
Thoughts?
KEJ316 is offline   Reply With Quote
Old 12-30-2014, 10:31 AM   #2
Rewards Points: 3,454
That would be my thoughts as well. What kind of pipe? Pvc, cast iron? How old is pipe going to city sewer?
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
BigJim (12-30-2014)
Old 12-30-2014, 10:32 AM   #3
Rewards Points: 4
Not sure what kind of pipe. House was built in 79.
Tags
bathroom , clog
Kitchen Sink Drain Pipe Clog problem after trying everything.. plumber1012 Plumbing 6 08-13-2014 09:29 PM
blue Scotts shop towel clog toilet pinkertonpv Plumbing 7 07-19-2014 06:51 AM
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
Slow leak under sink after fixing clog gunzour Plumbing 4 11-30-2009 09:27 PM
Sewer Line Continues to clog. Just Some Guy Plumbing 16 08-24-2009 10:38 PM
